Would 37" tires be pushing it?
Discussion in 'The Garage' started by Pookster, Nov 11, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Would 37\" tires be pushing it?
    So with the looming upgrade of a 8lug 10b front and a 14bsf rear, Im considering upgrading to 37" tires.
    I've run 35's on the stock setup and 3.73's gears and it wasnt too bad.
    Do you think it would be too much stress on the front with a eaton posi and 37" tires?
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Re: Would 37\" tires be pushing it?
    Depends on how you drive it. I've been running 38's on a D44/12b (both ends gov locked). I run it pretty hard and haven't broken anything yet. I go against the grain. Almost everyone here will tell you you HAVE to have a D60 and 14BFF for anything bigger than 35's. I don't subscribe to that theory. I say it all depends on how you drive it and the type of wheeling you do.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I think you could do it, but you would have to be pretty light w/ the skinny. You would always have to carry an array of spare parts for the front though /forums/images/graemlins/whistling.gif
    I have an 8 lug 44 w/ chromoly shafts and CTM ujoint/Ox ujoint. I still am a little nervous with 35's. Then again it's because I haven't broken anything yet /forums/images/graemlins/doah.gif
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I've got 36 Swampers on 6 lug 10 bolts front and rear. I take it easy off road,but I haven't had any problems yet (knocks on wood)
    I'm in the works for new axles. /forums/images/graemlins/peace.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I ran 38.5s on a 10/14 SF for a while. Never broke the rear but trashed the front every other trip. Now I have a 60/ff.
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    i've run 35's on my 10b without too much issues. im rather easy on the gas pedal, and since I dont do mud, wheel spin isnt much of an issue. But then again my 35's on alum wheels were just about as heavy as my 33's on steelies.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    It would be pushin it if you want it to be semi-reliable. I have ran 35's on my dana 44 for over 2 years without out breaking anything. 37's would be pushing it, but could be done.
    I was just thinking about some of the people running stock 10 or 12 bolt rears with 37" + tires, and my opinion would be if you broke a rear shaft while out wheelin with me I'd have to kick your a$$ /forums/images/graemlins/eek.gif Theres just no excuse for that. IMO thats like showing up to do some muddin with AT tires, might as well go back home and build your sh!t better /forums/images/graemlins/whistling.gif
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no reason for that? lightweight? good ground clearance. If I were to run 35s or 37s I'd consider running a lighter axle combo. Replacing a shaft is worth it to some people.
  9. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Well, a 10b and a 44 are pretty much the same strength... and I have absolutly ABUSED my old 44 w/ 38" TSL's and only broked 1 shaft... but it was an open diff.
    I would throw 37's on it, leave it open in the front, and call it a day. The SF14 should be fine w/ 37's.
  10. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    was just thinking about some of the people running stock 10 or 12 bolt rears with 37" + tires, and my opinion would be if you broke a rear shaft while out wheelin with me I'd have to kick your a$$ Theres just no excuse for that.
    Whatever man.../forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif I have seen guys break their 1 ton stuff running only 36's whereas I went through w/ no issues. That is a completely dumbass comment. Also, not everyone has the $$ to build a rig that is, in your opinion, correct. BTW, if anyone tried to kick my ass because I had breakage on a trail..I'd put a wrench through his skull.... /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  11. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    wheel what ya got!!
    If you break, most of the parts are not to expensive plus you get to learn more about your rig taking it apart /forums/images/graemlins/thumb.gif
  12. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Exactly! You know how many D44/12b parts I can go through before it's even close to the cost of going 1 ton??? /forums/images/graemlins/screwy.gif Actually, I will be going 14BFF soon, but I have no plans for a D60 for at least another year. Also I carry spare shafts. If I break a u-joint/shaft (which I never have), I swap in another shaft a take off. /forums/images/graemlins/waytogo.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The only reason I ever upgraded is because I was sick of working on it.
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think everyone that has gone 1 ton can tell you exactly how many times they redid the 1/2 ton crap before they wised up and went troublefree 1 ton.
    balljoints do not die as quickly
    brakes are better
    crossover is a few hundred less
    they retain their value
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yes 1 ton is the best option but not everyone can afford to go 1 ton so they have to work with what they got even if that means breaking a few axle shafts, they are not that hard to replace and are cheap to get. /forums/images/graemlins/thumb.gif
  16. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Well ok, I should rephrase that as you better have a spare shaft at least. One time on the trail with someone with a broken axle shaft and no spare is enough for me.
    But the heart of this is I think you are expecting too much from stock axles running 37" + tires. Front is one thing, but a rear 10/12 bolt is a different breed...and I did say stock, if you have some upgrades shafts in the rear you're probably alright.
    Wheel what you got, yeah thats a good saying, but it shouldn't be a liability to the rest of your group your wheeling with. You also should consider what you put on your truck then as well, ie 37" tires on f/r 10 bolts....that would not be a well thought out option if you see a lot of trails.
  17. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    It will be fine, I run basically the same combo, locked F&R with Iroks and have wheeled it HARD with no breakage. When I mean hard, its with the ARB engaged up front with all four tires spinning like mad at WFO on the rocks sawing the wheel back and forth trying to find traction.
  18. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Example...don't be this guy /forums/images/graemlins/wink.gif
    I am not the kind of person who would get mad about some thing or kick some ones a$$ out on the trail, but in the end I wasted a bunch of my gas driving to camp and back 2-3 times, and then the time lost not wheeling. So at least have a spare shaft cause its not fair to waste other peoples time and money cause you don't have a spare or haven't upgraded to one of those ultra expensive 14 bff... /forums/images/graemlins/histerical.gif
  19. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    37's on 1/2-Tons sounds like the "ragged edge" of tire/axle combos.
    Open diffs would help
    Gentle throttle foot would help
    Surfaces like mud/sand vs. rocks would help
    It's easy to say "just go 1-Ton"....since it's not my money, but money is always a consideration in real life. Then again, breaking down on the trail isn't FREE either, it can cost you your whole day of wheeling....as well as your friends' day and then the $$$$ to get your truck home and repaired.
    I guess if it were me, I'd be driving like there was a raw egg wedged under the gas pedal until I could either add some more beef to the axles, or do the proper axle upgrades. /forums/images/graemlins/waytogo.gif
  20. Emmettology 101
    May 9, 2000
    8,126
    FL
    Put it all in and run it. The 14SF is a good upgrade to a 10 or 12 bolt.... When you put the front 10b in, just make sure you use some good balljoints and u-joints..... If you're easy on things like you say, you'll be fine. Dont let the peer pressure get to you with the "You gotta run 1 tons or nothing" crowd.
