Would a 454 be too much for........
Discussion in 'The Garage' started by BigOrange90Jimmy, Nov 15, 2002.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I'm going to start building my Yota *ducking flack* and had a few ? before I make my decision. I've got a line on a 4x4 SRW 1-ton and thought about using the engine and axles from it. It has a carb'd 454 and a 400/205. I'm not going to use the 400 because I like my 465, but the 205 I will keep for the Doubler. The Yota will be ridin on 37x13 Boggers. Do you think this will be too much engine for this tiny thing? It will only be used offroad with the maybe once-a-week highway run.
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    LOL...
    I'm sure it's been done.. go 4 it man!!!
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Good luck keeping that "yota" cool!!The "yota" engine compartment is rather small,even for a SB motor.Get the biggest,thickest rad you can and make it fit. /forums/images/graemlins/cool.gifExuast system might be another area of concern.You know that the full width diffs are going to place those tires way outside the fenders,right?About 6" and that's with 8" 4"B.S. wheels.I was going to do this,sorta.I was planning on installing a 4Runner body on a K/5 frame,the wheelbase is about 6" longer than a toys.The fenders on a Toy are small and might be another problem.Hey, anything is possible...go for it!!I'd cut out the front wheelwells,though!Working on that BB is gonna be a pain!!One other item...the dist might be close to the firewall,so you might need a body lift.That would give some more ventalation and airflow.Mike
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I might just go with a 383 stroker motor. I still want the 1-ton though. The 454 just be something else to sell with it /forums/images/graemlins/thumb.gif I've gone through all of the points of fullsize axles on that. State laws don't mandate tire coverage. Fenders are no problem as I'll be running removeable 'glass on the front. The rear will be a flat-bed. Engine placement and radiator size has been addressed. I'm really doing my homework this time, not guessing like I have done in the past. You should see all the diagrams and sketches I have, along with calculations. I think the coilovers are going to be the best part. The frame will be boxed completely, hydro steering, rollcage integrated with the front clip and stinger, as well as the flatbed rollbar. TTC is calling.......... /forums/images/graemlins/deal.gif
  5. BLUESMAN
    Oct 3, 2001
    951
    Might be easier to just swap the "yota" body onto a K/5 frame.Alot less work and you know the frame is tough enuff.The motor mounts and spring mounts would be where you need them.Coil over in the front.....Cool!I'm doig something a little similiar,cutting a K/5 body 12" out of the width and bobbing 8" off the bed.I like the K/5 lines and want to confuse everyone!! /forums/images/graemlins/eek.gifI'm planning on throwing the body on my frame,which has 3/4 ton diffs,SB motor,SM465 trans(wanna do a dual 465 gear box!!).Good luck and have fun!!!
  6. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    We're going coilovers on a 4 corners Cap'n! /forums/images/graemlins/eek.gif I know I'm going to be dropping the cash on those puppies. I would put it on a K5 frame, but I'm going with the Yota extended cab frame so I will be able to play with my wheelbase a little more than a K5 frame would allow. I'm just ready to fabricate something from almost scratch.
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I think its a terrible idea, you better just give me the 1 ton truck /forums/images/graemlins/smile.gif
  8. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I'll give you what's left of it. So that will be a 454, 400, 14 bolt, and a complete chassis and cab.
  9. outlaw612
    Feb 11, 2001
    2,342
    Man Id love to have a 454 /forums/images/graemlins/smile.gif
  10. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    yeah i would love to have it too
  11. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    You can buy it as soon as I get the truck.
