would a power steering pump work for this??
Discussion in 'The Garage' started by 82GMCP/U, Nov 2, 2003.
  1. 82GMCP/U
    82GMCP/U Registered Member
    Feb 13, 2003
    37
    Lake George, NY
    Would a power steering pump work to run my hydralic plow set up? I know I would have to add a resivior to hold more fluid, but would it have enough oumph to run the steering and the plow? Thanks
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you would need to add cooling and modify the pump and I still think you would have unresponsive steering when using the plow.
  3. 82GMCP/U
    Feb 13, 2003
    37
    Lake George, NY
    what kind of mod. would I have to do to the pump?
  4. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    If you use a second power steering pump and add a reservoir by putting a junk of rad hose on the neck, they work great. They beat stock fisher pumps all to hell. They will angle with a full blade at idle and as soom as you hit the lift, the plow is up, no sitting and reving.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Be careful of using radiator hose though. It's not intended to have oil in contact with it. It will swell and blister inside, then one day it will start leaking. A quality parts house should be able to set you up with hose up to the job.
