would an 86 silverado have criuse?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bryguy00b, Mar 22, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my signal/wiper switch has the button on the side od it and a little toggle switch on it...thats for criuse right...how do i work it to see if it even works? (i doubt it does)
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes cruise, will say on SPId label in glovebox if is factory installed and not a column swap by a p/o
    you flip the switch to where it says ON and then you depress the button on end of the turn sig handle when you get up to 55 or whatever, it will remember this speed that you turn it on at so when you ever want to cruise at that speed again then you flip hold over to resume and then let go
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    which way is on? the labels are worn off of the lever...
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    The switch should be a 3 position switch. It will be:
    OFF-ON-RESUME(or coast, basically, if you push it all the way to the right it will go back to the speed you last had the cruise set at)
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The third position is called "resume/accelerate" and the button will slide over to position 3 but if you let it go it will slide back to the "On" position.
    While cruising you can use the position 3 to accelerate and bump up your cruise speed.
