Would full length skid plates raise underhood temps?
Discussion in '1936-Present Suburban' started by SubYuman, Mar 1, 2005.
  1. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Someone just handed me a 36x84 piece of stainless diamond plate...I want to cut it in half and use it to build motor to trans skid plates...will they not allow heat to escape from under the chassis?
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Diamond plate is pretty slick but only worth it depending on the thickness. I wouldnt really worry about heat build up too much. Theres quite a bit of room for air to flow around through the chassis.
    Apples and oranges but I know a 'yota guy who runs a bud built skid plate that literally goes from the front bumper past the tcase and theres less room for air flow in his setupand he has no isues
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    your worryed about the moter? the oil pan?
    it wouldent raise the temps any more that you might even notice.
    i would think it might even help header to starter transfer because it would cannel the air past the moter.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    being underneath the engine, its not gonna retain any heat really.
  5. SubYuman
    Oct 13, 2001
    246
    Edwards AFB, Ca
    Not too thin...
    I can't say for sure, but I know this stuff is tough..stainless diamond plate, the sheet easily weighs 80 lbs...As big as I am, it's size makes it hard to move...
  6. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    skip plate....heat rises doesent it?
    I dont think there would be to many heat issues as long as your radiator works. mabey a oil+ trans cooler if your really concerned.
