Would I be a moron if...
Discussion in 'The Garage' started by mikey_d05, Jun 27, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I went on a weekend wheeling trip without spare front axleshafts? I've got lockouts and u-joints, but I can't find shafts around here for an anywhere close to sane price. It's a D60, and I run 39.5's with a tired 350. It'll be mostly tight trails with a few rocks and a lot of mud thrown in. My friend wants to go the weekend of the 9th, and I'm up for it except for this. If I drive with my head instead of my cajones I should be fine, but junk happens and I don't want to be "that guy". Besides, this will be this truck's shakedown run so I'd like to be able to run it the whole weekend. Grrrrr....this is making me crazy....what do you guys think....should I give it a whirl or am I an idiot for thinking about it?
  2. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    I think you should be fine... like you said... use your mind not the balls... just don't do anything harder than you think you could handle... if it's questionable terrain... don't do it. Better to say "well I think I coulda done it" than to say "oh ****..." basically
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If your sig is correct and you've got a locker in the 60, I'd be real careful without spares.
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    It's a trac-lok, which is Dana's weak limited slip diff.
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    I don't think it's impossible to break D60 stuff, but it's a lot less common than 1/2 ton stuff. At BB03 i saw FWP frag a Spicer U-joint, and 73K5tony snap a stub shaft. Fred was trying an optional and was on the stupid pedal pretty hard while bouncing. Stub and shaft were fine.
    Tony got a 44" TSL stuck under a rock shelf on Upper Helldorado. Both guys were running 30 spline stuff and regular U-joints. I wheeled the entire weekend there without spare shafts, and I'll do it again at BB05. From what I have seen first hand the 30 spline 60 stuff takes a hell of a beating before letting go.
    Rene
  6. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I agree with tRustyK5, I have beat on my 60 prettty bad and not broke anything, hell last trip I got one of my 38.5 SX's I was running then spinning and bounincg hard enough to do a nice smoke show. I got pics if you want proof. I would not worry about it, I don't carry any spares with me and probably won't at BB'05 either.
    Krennen
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I got a detroit.... no spare front shaft.... and hammer foot is my nick name :laugh:
    ***edited...
    however I am getting a 1 piece rear d-shaft from a bud.. so gonna use mine now mounted on the bed wall for a spare.. I also have a front shaft which is too long.. just needs to be cut down then I will carry spares..... One day I expect to carry extra shafts, universals, tools, alt, water pump, starter, belts...... :grin:
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I would go, and be easy on the skinny pedal. Things happen, but you can't let the possibility stop the fun or you will never go anywhere.
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    With a Dana 60 front and a weak limited slip I wouldn't be overly concerned about not having spares......from my experience most people with front 60's don't carry any.
    With that said, I have broken 3 shafts on my Dana 60.
    1. the old necked down short side inner
    2. pass. side stub
    3. driver's side stub
    These were all on different trips. I'm running 38's with a front Lock-right. The stubs let go while getting on it pretty hard while on rocks.
