Would it be bad if....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RustBuket, Aug 28, 2003.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I overfilled my tranny with fluid? It comes up past the full mark by quite a bit and I'm so lazy and don't really want to mess with draining some off its it not that big a deal. Will I be hurting anything? /forums/images/graemlins/confused.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Yep, it's hard on it because it causes air bubbles in the tranny which generate extra heat.
    85K5 3/4ton,14boltFF,10bolt,9"lift, 35"boggers, 16.5x14 welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  3. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Easy way to drain transmission fluid is crack a tranny cooler line and start it up for a little bit to drain some atf out of the tranny. To not be a messy job, use 3/8 fuel hose and a milk jug to collect the tranny fluid. That way you can see what you drained out and you can go from there /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just loosen the line at the radiator, start it up, and shut it off real fast. I'd run a rubber line from the line into a drain pan though, otherwise it'll spray all over.
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    And it's hard on your driveway when you park your truck and all the pressure that's built up inside your tranny gets vented(along with a bunch of ATF) onto the pavement or concrete below.
  6. Grim-Reaper
    7,385
    Atlanta
    This is while running in Park HOT it's over filled? It will read high with the engine off.
  7. RustBuket
    Feb 21, 2003
    1,618
    Yes, its with the engine running. I'll do that then.
