Would it look weird with 42's and 44's together
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, May 12, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    Would it look weird with 42\'s and 44\'s together
    I would like to do 42's in the front since they are only 15"wide. Would it be ugly with some 42 TSL's in the front, 44's Boggers in the back?
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Re: Would it look weird with 42\'s and 44\'s together
    I wouldn't do it for two reasons. One you would have to have diffrent gears in each axel. Two you would have to have two diffrent spare tires unless you never planed on getting a flat!
  3. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    well 44s and 42s dimentionally arent that much different. The 44 is like 17 wide i think? Im pretty sure the actual contact surface of the 44 is really close to that of a 42.
  4. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    The gears I'm not too worried about. The only time I ever use 4 wheel drive is in mud, the tires are spinning then anyway. And if I get a flat I'm outta luck since I don't carry a spare. Would it look stupid though? I like the fact that you can mount 42" TSL's on a 9.75" rim. 44's require a 12" wide wheel or at least Interco recommends.
  5. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    just go boggers all around
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Just go ahead and use all 42's or all 44's. You can put a 44 on a 9.75" wheel. I keep my spare 39.5x18 bogger on one. My 44's are on 12" wide wheels, but they woud work just as well or better on a 10. As for looking stupid, It would be more how the vehicle was setup than just the tires.
  7. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    That's what I would really like to do. Boggers all the way around. 10" susp lift, how much more trimming would I have to do to fit 44's opposed to 42's?
  8. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    I'm running 44 tsl's with 8" of lift on a 79 k10. I can make them scrub if it gets REALLY crossed up. With 10" you should have plenty of room if you trim fenders.
  9. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    By trimming you mean just a little off the sides, right 8)
  10. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    There is NO WAY that the contact of a 44 Bogger is anywhere near the contact of a 42 swamper. The Boggers are WAY wider, WAY wider.
    Ken H.
