would like to get some help
Discussion in 'New England Region' started by NEK5, Aug 14, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    to change my axle shaft in my rear end, and swap in my new front end....would like to get a few people to help, could buy food/beverages, pay labor......let me know guys, i`m in lynn, MA
  2. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    not sure yet, what would be good for everyone, sometime in the next month.....?what would be good for you?
  4. the beast
    Oct 15, 2003
    535
    Providence, RI
    Personally, weekends right now are tough with club stuff, meetings, association stuff, etc.
    I might be able to squeeze a week day in, unless I find a job.
    But don't go by my schedule.
  5. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,229
    487
    New Hampshire
    Wish I could help but once school starts on the 29th I will have no time on my hands at all. Plus I work weekends.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmmm, maybe before the 29th??:thinking: :thinking:
  7. Chevy305
    Jan 23, 2006
    11,229
    487
    New Hampshire
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    anyone here good at tranny work? got kit #30 from www.700raptor.com and i could use a little help on the install...looks like i might be able to do the front end with my buddy and his dad, but not sure when
  9. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    the hardest part of the install will be installing mega valve and the oversize low/reverse valve. Once the pin that holds them in is removed they should fall right out. Becarful, there is more then just the valves that fall out. If you have the tranny out then everything you are installing will be somewhat easier. I rebuilt my 700r4 using GM Automatic Transmission Overhaul book by Haynes. Very good book. Easy to understand. The servos can be a little stubborn. I used a flat head screwdriver to pry the ring that holds the servo cover on and used a pair of channel locks to rotate the cover off then just tapped the cover back on with a rubber mallet. Not all that hard. If you can swap a rear then tranny work is easy.
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thats the problem, i cant:D
