would my truck run with out a ..... attn pauly 383
Discussion in 'The Garage' started by down4thakrown, Apr 24, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    gauge cluster? all the wires that go to it have been cut right before the plug for the cluster. i dont plan on useing the stock gauges. goin with the triple gauge set up at the Zone for 32.99. and eventually set up a custom dash. thx
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Yes.
  3. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you have a factory tbi truck (pre vss in tcase) it has a vss in the speedo and adjusts the tbi to run differently. it will still run and not too much differently, but will efect it.
    if no tbi then forget what i said
  5. dyeager535
    26,979
    VSS is tied into cruise control as well, if it's the "electric" style cruise control instead of the earlier transducer style. Not sure when they went with electric cruise vs. transducer, but I suspect around 1982.
  6. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    might not charge...
    If they cut the harness to the printed curcuit board,they might have disabled the "altenator" light--if your tuck has a voltmeter and its still wired up,disregard this--but cutting the altenator idiot light out of the circuit on trucks equipped with idiot lights VS gauges also cuts the 12v source to energize the feilds in the altenator and make it charge,so you'll have to run a new wire to the altenator plug from the key,thats hot only when its in the "on" posistion... :crazy:
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i dunno if it had an idiot light, i bought the cab form marv. i think pauly took the gauges? i dont plan on useing factory gauges, i was gonna go with the triple gauge set up for now. would i be able to just run a hot wire straight from the altenator to the batt. thats how i did my 83 k5 when i bypassed the worthless cpu under the dash.that was when it was still a d.d.
