would need new longer shocks for 2" lift?
Discussion in 'The Garage' started by bryguy00b, Nov 16, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    would need new longer shocks for 2\" lift?
    could i do a 2" lift and still get away with using regualar length shocks?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Re: would need new longer shocks for 2\" lift?
    You can use the stock shocks, but it's better to get longer ones. Order the 2" kit and you'll get shocks with it.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Depends...I know Rancho's PN's are for stock, and then the next step up is 2.5"-4"...so you can, just make sure they are not the limiting factor in the suspension or you will get to replace shock mounts too.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Oh, by the way i just happen to have 2 RS9000's that would fit quite nicely on the front of a K5 lifted abotu 2"...so to answer your question, yes you do need new shocks, right now... /forums/images/graemlins/thumb.gif
  5. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Are they the adjustable one's?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    yes they are...forget the rancho pn, but they are 14" long compressed and 22" extended, fit on the front for a 2.5" - 4" lift, used them for amybe a month, then took off for a smoother ride
  7. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Are they stiff shocks? I'm in need of some soft shocks for my stiff lift. I was wondering since they had the adjustability if they were soft.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The ycan be soft or stiff...setting 1 is really soft, 2 a little harder, 3 is just like rS5000's, 4 stiff - good for towing - and 5 is really stiff
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    how much you want for them?
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I sent you a PM
