Would the bellhousings be the same
Discussion in 'The Garage' started by 70jimmy, Jul 31, 2006.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,959
    249
    Released from Pueblo, told I belong in Southpark
    1987 Blazer with 305, 4 speed sorry don't know which one, 4 wheel drive, hydraulic clutch. Would a 1989 Chevy 3500 pickup with 4speed that was 2 wheel drive be the same???
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Should be, I think they changed it when they went to the nv4500
  3. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I believe he has a 465 gear box.
    It seems to me that they would swap.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All Chevy v-8's since 1955 have the 90 degree bellhousing , all inline sixes since 1962 have the 90 degree bellhousing , the diesels and 90 degree v-6 have it too .
  5. 70jimmy
    Mar 3, 2000
    5,959
    249
    Ok any idea if the 89 would be hydraulic clutch????
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Should be hydro from mid 85 on IIRC .
  7. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Correct me if I am wrong, but wouldn't the bell from the blazer have the slave on the driver side? I know for a fact that the 88 up "K" series have the slave at about 5 o'clock on the passenger side, in order to clear the IFS diferential.
    Jimbo
    Oops, re-read the question, and yes, the SM465 is the same between the 87 blazer and the 88 K3500. The 88 K3500 has a different top cover which relocates the shifter rearward about 5". Can get pics tomorrow if needed.
    Jimbo
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    if the 88-up has a 5 speed no it wont work as that tranny has a molded on bell.
    but some early 88-89 trucks had 4 speed 465 trannys. these might just work but i have not tried this.
    and as for the nv4500 no it wont bolt to a 465. bolt spread is bigger and center hole is bigger.
  9. chevyryan
    chevyryan Registered Member
    Aug 1, 2006
    13
    colorado
    yes they will. for the most part all chevy small block parts are interchangeable. i know ur bell housing will work tho.
