would these wheels work for 14ff?
Discussion in 'The Garage' started by 5trucks, Feb 13, 2007.
  1. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
  2. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I may be wrong but I dont believe that 15 inch wheels fit on one ton gear without grinding down the brake calipers and getting different rear drums.
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Your 1/2 right. 15" wheels wont fit over 3/4 ton front rotors (8 lug D44 or 10B), and they also wont fit over D60 1-ton fronts. To solve this problem, simply grind down the excess metal on the calipers until the wheel no longer hits. As for the rear 14ff, 15" wheels WILL fit over the stock drums. No need to clearance these or change drums.
    -Harrison
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Exactly, I run the same exact rim in a US Wheel flavor vice Cragen but same specs and I have a 60 that I ground a ton on and a stock 14FF with the large drums.
    Ira
  5. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    I have the small drums on my 14ff so that is what i was concerned about. The fronts were not a problem. What about the backspacing? All good with what the wheel says it has?
  6. sandawgk5
    Oct 28, 2003
    6,881
    Yep I run 4.25 on mine.:D
    Ira
  7. 5trucks
    Aug 12, 2005
    169
    Yuma Az.
    Cool! Ordered the wheels. Now i need to order the rings for the beadlocks.
