Would this be a good time for hot tanking? Have a gritty axel!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Oct 5, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I recently had my axel sandblasted so I can paint it. Well, the whole thing got sandblasted inside and out and I have grit all in my housing, carrier, gears...everywhere. I stripped it down and used a small pressure washer to clean it out but it is still gritty. Would it be a good idea to have it hot tanked? Any other good Ideas?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You could try a steam cleaner.
    90K5
  3. getsome
    getsome 1/2 ton status
    107
    Colorado
    Last time that I asked a machine shop if they could hot tank an axel they said no because the hot tank was not big enough for an axel.
    Getsome
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    If no machine shop has a hot tank big enough (call around), use the pressure washer a few more times. Spray some Castrol Super Clean all over the innards and use brushes to scrub as best you can. I think PAW has a brush kit for engine blocks that could be used.
    [​IMG] Semper Maintenance!
