would this be enough to pull?
Discussion in 'The Garage' started by moose73, Jun 1, 2003.
  1. moose73
    moose73 Registered Member
    Apr 11, 2003
    22
    chatt,tennessee
    have a 76 blazer with 36's, wondering if a 1500 dodge extended cab four wheel drive would be enough to pull. im guessing truck and trailor to be 6500-7000pnds fully loaded.any comments.
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    On the door sticker, there should be a block that will give you the Gross Vehicle Weight Rating.
  3. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    i dont think pulling would be a issue, but stoping might be /forums/images/graemlins/ears.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  4. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    Yeah trailer brakes are a MUST. I pull a 6000# boat trailer, and you KNOW when the brakes arent working
  5. Grim-Reaper
    7,385
    Atlanta
    I just pulled a stock 70 on a trailer that weighed about 2500lb with my 3/4 454 burb......It's a lot of weight and I wouldn't do it with a 1/2 ton. Trailer had brakes so that was not the issue it was just the shear weigh. I'm pretty sure you going ot be well over the GVWR for the Dodge. I was right at it on the Burb and My max GVWR with trailer and the gears I have is 16k.
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    Yeh, my vote would have to be NO. thats just to much for a 1500. Sh!t me pulling the same rig with my 3500 SRW was a hand full, don't get me wrong my 3500 would do it all day but it sure let you know there was 7000 pounds behind ya. /forums/images/graemlins/eek.gif
  7. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    I have to agree with the others...don't think a 1/2 ton would do it(very well anyway). Trailer brakes are a must!!!
  8. moose73
    Apr 11, 2003
    22
    chatt,tennessee
    thanks for the input everyone. my gut said probably not but wanted to ask. a 1/2 ton would've got me a tow rig faster. ill hold out for 250 or 2500 diesel.
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    you know the towing max of a ford explorer (old style) is 8k not saying it's a good idea, but that's the factory max rating. i'm thinking a dodge 1500 with a 360 would do it, maybe not a 318 or v-6, but a 360 would. if the trailer has brakes and you don't need to go real fast or stop real fat then you should be ok. just follow a long way back, and stay at the speed limit. i've towed a 6.5k trailer with my dad's V-6 exploder, not easy, but the trailer had brakes so it could stop- also helped that the X has four wheel discs. just be careful.
    my $0.02
    red
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I towed home a '77 1-ton Chevy pickup on a tandem axle car trailer with a Ram 1500 quad cab 4x4 last fall. This particuliar 1500 Ram is about as heavy-duty for a 1/2 ton as you can get stock from Dodge. It had a 360, auto w/ big factory auxiliary cooler, 4.10 gears w/ stock tires, factory tow package (pre-wired for trailer brakes), and the heavier springs and shocks that come with the "Off-Road" package. I also had a weight distributing hitch w/ 750 lb. bars and trailer brakes.
    It was no problem what so ever, plenty of power to get going and no problem stopping or handling. Here in Ohio there are no mountains to climb but I could maintain 55 mph on 2-lane state roads while going up mild inclines without downshifting from 3rd (had the O/D off). I did not get to try the freeway though.
    I would not even consider doing this without the brakes and weight distributing hitch with the 1/2 ton. My biggest concern would be long-term longevity of the vehicle if you towed quite a bit.
    If possible a 2500 or 3500 would obviously be better.
