would this EFI system work?
Discussion in 'The Garage' started by beater74, Oct 9, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I dont see why not. Dont know if they will bolt to your heads though. Somebody here should know...
  3. beater74
    May 29, 2001
    1,749
    atlanta
    that would be important
  4. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    Unless you have Vortec heads, it should bolt right on.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it'll fit unless you have Vortec heads. /forums/images/graemlins/cool.gif The angle of a few of the intake bolt holes changed slightly when GM started using the one piece rear main seals, but with a small amount of grinding you can modify the holes on the TPI intake to fit pre-86 heads. /forums/images/graemlins/smile.gif
  6. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Or, you can buy my '85 TPI base that will fit with no grinding and I can buy the Vortec base to fit my heads! /forums/images/graemlins/thumb.gif
    Mike
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I would hold out for a speed density setup (90-92). It's much easier to install and tune, has less wires and relays, and doesnt have that cold start injector crap /forums/images/graemlins/rolleyes.gif. Also this guy seems to think his setup is worth more than it really is /forums/images/graemlins/rotfl.gif. You need to machine the 4 center intake bolt holes for the different angle of the older heads and you need beveled washers (search on mcmastercarr.com) so the bolt heads sit flush when tightened. I have pics of how do do this if you need them /forums/images/graemlins/k5.gif
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Wouldn't the MAF sensor FI system be alittle more forgiving of non-stock applications thus easier (than MAP) to "tune".
    /forums/images/graemlins/smirk.gif
  9. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">No, speed density PROMS are 32 bit as oposed to MAF PROMS which are 16 bit, so theres twice as much range of adjustment.
    also MAFs are delicate and expensive (about $300)
  10. beater74
    May 29, 2001
    1,749
    atlanta
    thanks biggray /forums/images/graemlins/thumb.gif yeh i think i'm gonna pass on this one
  11. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Very easy to change from MAF to SD by the way............... /forums/images/graemlins/thumb.gif
  12. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    It looks like you'll still need a fuel pump and and air filter settup. Setting up the fuel pump can be expensive if you don't already have a TBI truck. /forums/images/graemlins/cool.gif
    Mike
