would this work on my rig?
Discussion in 'The Garage' started by colbystephens, Jan 20, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    so that's the correct size for my brake line application?
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    depends on what you want to use it for... ebrake?
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yep. i've got a buddy who runs a similar one on his 1ton ford diesel and it works for him... soooo??
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I think he wants to do some burnouts at the track to warm up his mud tires for quicker ETAs with the, well known for its speed and power, 6.2. :D :D
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    :haha: well, i can peel out on dry pavement pretty easy w/ my 6.2... does that count?
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    then no, it wont work. the first time you leave it engaged for any period of time, it will kill the battery.
    you've got a 205, now its time to call Jesse. :deal:
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm thinking e-brake as far as being on the trail. it sux to have to shut off my truck every time i want to take a look at an obstacle. i'm not thinking for parking brake... my 465 holds me in place just fine.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    then yeah, it would work perfect.
  11. goldwing2000
    goldwing2000 Guest
    I would try to find one that uses double-flare fittings (like on a normal brake line) instead of NPT fittings.
    Maybe even a manual valve instead of an electric one.
    Less complicated=fewer things to go wrong.
    Cheaper, too.
    I've seen them before but I can't seem to find them now. :doah:
    edit: MICO makes manual locks but they're more spendy than the electrics.
    edit2: have you thought about fixing the regular mechanical e-brake the vehicle came with?
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    cables hanging under the vehicle are bad, m'kay? plus, the line lock as an ebrake for the trail would open him up to running discs on his 14FF using standard 3/4 ton calipers without worries. i'll agree with him, that in a parking situation, the 465 should do just fine without an ebrake.
  13. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    could someone please explain how this setup works? I don't have an ebrake either, but it would be nice to to have some sort of ebrake out on the trail...only for trail use like what colby want's to use it for... I'm running disc brakes out back....
  14. goldwing2000
    goldwing2000 Guest
    Push brake pedal.
    Engage line lock.
    Line Lock holds pressure to brakes.
    Exit vehicle and see how deep the mud/water really is.
    Re-enter vehicle.
    Push brake pedal.
    Disengage line lock.
    Put vehicle in gear (forward or reverse, depending on how deep the mud was).
    Continue on!
    I'll buy that.
  15. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    cool thanks...
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    line lock only keeps the front brakes engaged making burnouts a possibilty too! :wink1:
  17. goldwing2000
    goldwing2000 Guest
    You could also put it on the rears if you're only using it for a parking brake.
    That would also give the benefit of being able to use it as a cutting brake.
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    define cutting brake
  19. goldwing2000
    goldwing2000 Guest
    Technically, you'd need two line locks for a genuine cutting brake but the purpose of one is to provide the driver the option of locking either the left rear wheel or the right rear wheel to help improve the vehicles cornering ability.
    edit: Of course, there are other things to consider, as well. If you don't have open diffs, it would also require either a NP203 full-time t-case or a twin-sticked case that you can put the rear in neutral.
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    line locks cannot be used as a cutting brake. you'll need a cutting brake to work as a cutting brake.
    they're commonly found on dune buggies for steering in wheels up situations.
