would u buy these tires?
Discussion in 'The Garage' started by smokkey1, Nov 24, 2006.
  1. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I have a chance to get some 37x13.5x15 extrains for very cheap with 90% thread left. but one of the tires has a torn piece of sidewall by the bead. I guess the guy at the tire shop tore it when he was dismounting the tire. heres a pic of it. so should I get them... I need something that's a little more street friendly than my bias swampers....
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Do you plan on wheeling with these tires or just using them for the street? If just for the street I would say they are fine but if wheeling with them it might be a little risky because of the sidewall flexing and lower tire pressures. Dont be a wuss I have been running my 38.5'' bias on the street and there fine, I just dont have any fillings in my teeth anymore.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    that would make a good fullsize spare. depending on your state inspection laws that probably isn't legal. In PA it's not. a retread shop should be able to put a spot repair on that, unless the cords are torn.
    I personally would run it, one of my tires has a huge patch in it that you can see through ther tread. I installed the patch back when I worked at a tire shop, so I know its done right. the hole is big enough that you could stick 2 fingers through it. This of course is on a trailer/trail only truck. and I carry a fullsize spare.
  4. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    if the cords look good its a quick repair. maybe costly repair depending on where its done. what they will do is fill it in with some rubbery goop then cook it and it will just be a lump right there they should shape it for proper bead seating and everything, at my tire shop, if that came up for me to buy i wouldnt buy it unless it came repaired by quality bandag professionals. but I would buy it and repair it and run it as a spare
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Buy them and go get one new one. Use the torn one as a trail spare.
