Would You Buy an Axle Truss?
Discussion in 'The Garage' started by Depdog, Aug 15, 2002.
  1. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I have the ability (JD2 Bender) to make some axle truses (over the top of the axle) out of 2" .120 wall tube. I was thinking from over the diff to going down just short of the leaf spring mount and then two legs straight to the diff, one on either side of the main housing. This would be a weld in deal only. If you have seen the 2" square one on my K5 (this was before I got the bender /forums/images/icons/grin.gif ) You have an idea on what it would look like. Anybody be interested in these for like $75.00 plus shipping?
    I may also build some other things upon request.
    Depdog
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    one thing i'm interested in is, i'm fix'n to build some rock sliders like grims but i would like some rails that extend off the side to help provide side body protection (kinda like yours) could you bend up some tube for something like that /forums/images/icons/smile.gif
  3. Depdog
    1,657
    Georgia
    Yep, sure can. What kind of bends do you want?
    Depdog
  4. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    How about a rear upper shock mount similar to that found on Project UAV?
  5. beater74
    May 29, 2001
    1,749
    atlanta
    i'm leaning towards a set like yours but out of tube. i'll give ya hollar in month or so. (as soon as the wife lets me buy my miller 175) /forums/images/icons/smile.gif
  6. Grim-Reaper
    7,385
    Atlanta
    Need a test truck? /forums/images/icons/smile.gif I been thinking about building one for mine just like you described. I would be interested in one.
  7. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Do you have a preliminary design in mind for a D44 or D60 front?
  8. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    gonna make trusses for just ff14b rears or D60 fronts to? /forums/images/icons/laugh.gif
    J
  9. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    if I was 1-ton and trussed... i wouldnt mind jumping my rig on sand dunes and crap, lol!
    J
  10. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    My thoughts exactly! /forums/images/icons/wink.gif I would own the local tough truck races. /forums/images/icons/grin.gif
  11. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    if you would make one for a 14bolt SF i'd be interested. /forums/images/icons/cool.gif and if i could get one made for a 10 bolt front, i'd be happy. /forums/images/icons/smile.gif what does yours look like so i can get an idea? do they look like the MOO ones?
  12. Depdog
    1,657
    Georgia
    I have not thought about the front truss's only rears. I can make them for any rear axle. Wont matter if its 12 bolt, 10 bolt, Dana 60, 14 bolt full or semi floater.
    On the rear shock mounts, where do you think he got the idea from? /forums/images/icons/grin.gif
    I can make one of those too. Would you want just the weld in bar, or the shock mounting pieces as well. I use 2" square tube and cut one side off it to make it a C shape. Drilled a hole in it and used a pair of stock rear shock mounting bolts. The bolts I dont have. Everything else I do, you would have to let me know how far apart you want the mounts welded, or I could just include them and you could weld them where you want. How about $50 bucks on the three pieces. Bent up tube and the pair of shock mounting pieces. I have some ideas in mind on the rear shock mounts, just have to test them out first.
    Depdog
  13. Depdog
    1,657
    Georgia
    Since I dont think I made this clear, this would be a weld on truss, I dont have the parts to make it bolt on.
    Depdog
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    How come no one makes them for a rockwell?
    this seems like an untapped market
  15. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    *Opens mouth widely and slowly inserts foot.* /forums/images/icons/crazy.gif Sorry, I had no idea. Anyways that sounds like a good deal to me for the three pieces. I am still trying to get my 14-bolt slung under my truck so I really don't have a good idea on how far apart I want my mounts welded yet. I am open to suggestions, though. I am not in a HUGE rush for the shock system as I still need to purchase some new rolling stock, but I do want a setup.
  16. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    no front trusses? bummer! if an axle is going to get tweaked 'cause I jump my rig, its prolly gonna be the front one. /forums/images/icons/frown.gif I could put one of the ff14b i guess... but its already tough as hell, and there is no weight on the rear end compared to the front so it'd sorta be like overkill in the rear end and not enuff up front.
    J
  17. Depdog
    1,657
    Georgia
    I did'nt say NO front truss's just that I have not even looked at making one right now. /forums/images/icons/grin.gif Gonna be tight trying to fit one on top in the front.
    Depdog
  18. Mike.S
    Mike.S Registered Member
    Jul 4, 2002
    30
    S.E.TN.
    I was wondering about something ?, do you think the .120" wall is strong enough for being a axle truss ? I assume the material is 2" square and that in it self will offer some strength but if you can imagine the force it takes to brake a axle, will these truss's be able to handle a braking axle and prevent it ? I know that the truss's "ADD" strength to the axle but for the time, effort and expence wouldn't .250" (1/4") be worth it ? I don't mean to pee in your Cheerios, I'm only asking since I don't know what a typical axle truss is made from. /forums/images/icons/confused.gif /forums/images/icons/grin.gif
  19. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah fitting on top of a front axle would be a pain... definitely require lots of measuring, fiddling, and engineering. /forums/images/icons/wink.gif
    J
  20. Depdog
    1,657
    Georgia
    I was talking .120 wall round tube and the truss is to reinfore the axle. The one I have on mine now is 1/4 wall 2" square tube (did not have the bender then) With the .120 wall tube and welded on, I think you would bend a flange on an axle, or maybe the end of the axle housing just the other side of the spring pad. The tube tied into the axles tubes would give strength through triangulation.
    Depdog
