Would you do a shackle flip again for DD?
Discussion in 'The Garage' started by Ned Kelly, Jan 29, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    For those of you out there who dd their trucks on the street/highway/trail - would you do a shackle flip again? Just wanted to confirm before I commit to doing the 1ton Burb in this manner. I'm leaning towards DIY4x4's kit.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine has a shackle flip and I love it both on road and off. It kept he original spring rate so it is not as harsh as most rear lift springs.
  3. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    why even ask. he!! yes . if my plow/work truck wasnt going to me heavy duty work truck it would have one. my crew cab will be getting one vary soon.
    my old 83 there was no comparison from stock to fliped. it just road better.
  4. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    x2... i definately perfer it over a tension shackle setup
  5. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    X3 love my shackle flip.
    ~Brian
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I might not if I was going to tow alot. Other than that, you can't beat the ride.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i definitely would do it again
  8. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    I did it on my last dd and am fixing to do it again on my new one. better ride, more flex and cheaper then leaf springs. I got mine from a salvage yard for $25.:D
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Ditto. Just done 2000 miles on my new suspension and it's broke in real nice. 4" EZ ride up front with zeros and flip/zeros in the rear. Love it.
    I use a panhard when on the road to tighten up the feel but pull it for flex off road. I'd definaitly go this route again.
  10. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    Do It!! Do It!!
  11. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Why do i see these post, "not if its heavy duty" "not if im towing"
    A flip is stronger than that crappy stock bracket... no reason not to run one in ANY truck. If you had a killer shackle angle and super soft springs, id yes yes, it would comprimise handling but other than that no way:rolleyes:
  12. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Thanks for the responses guys - I think I'm going to do it. On occasion I do tow a small trailer with two dirtbikes and some camping gear, but a small trailer. I shouldn't have a problem with towing. I think someone elso in a thread long ago said they had no problem towing with a shackle flip, and it was a trailer on the heavier side.
  13. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    If they made one for my DD I would get it to eliminate the factory block. should have done it sooner on my woods truck, and have the flip ready and waiting for my blazer once the tires wear out enough to justify bigger ones.
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am pretty sure GM is the only one still using a tension shackle on any of the trucks made nowadays.
    Ira
