Would you like a roll cage?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Gold Rush, May 7, 2000.
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I've been wanting to install a good roll cage and haven't found any bolt ins for a reasonable price. Yesterday I went to the local steel & recycling yard and bought 1.5" ID / 1.9" OD pipe that the local racers use on stock car roll cages. It cost about $1.80 per foot. With tax I spent $36 for 2-8', 1-5'and 2-4' pieces and 2-4"X6" 11 gauge flat pieces. Exhaust pros said they could bend the pipe with their machine so off I went. I told them how I wanted it to look and they bent the pipes. Only cost me $15 for bending them. A friend helped me measure and spot weld the pipes together. Since we had no way of notching the tubes I used a grinder. I took it out and welded it all up and then painted it. This morning I put it back in and welded it to my factory roll bar and then welded the 4"X6" bottom plates to the floor that I have reinforced with 2 layers of 14 gauge steel ( replaced floorboards and then added another layer to make strong enough for roll cage). I have about 8 hours and $54 dollars ($36 for pipe, $15 for bending, $3 for primer and paint) in this project that just might save my life someday. I will be extending my cage to the rear area in the next week or two so I'll post results then also. I was unable to take a picture today so I'll take one tommorrow if the weather is good and post it.
    David 75K5
    http://www.renschler.org/~goldrush
  2. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    Post some pics goofy top guy! Sounds good!
    "You're right... I don't understand that Jeep thing!"
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    That sounds great. Money is the only reason I don't have a cage on my '73, now I won't have an excuse. Look forward to seeing the pics.
    Mud is just thick water, or is it that water is just thin mud?
  4. Gold Rush
    1,498
    Post deleted by Gold Rush
  5. Gold Rush
    1,498
  6. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    Re: another pic of cage
    NICE JOB! I like it, Rush!
    Blazin' in Flagstaff
  7. Gold Rush
    1,498
  8. Gold Rush
    1,498
  9. ggallin13
    ggallin13 1/2 ton status
    Mar 31, 2000
    199
    Northern Nevada
    That looks great! Very resourceful of you. I am putting one of those in mine. DO you have any kind of plans drawn up, or what? I can't weld at all, so I wll have to give as much info to guy as possible. I am checking to see if my local community college is teaching welding this summer, but I want a cage now! I know first hand that such a thing will save your life! [​IMG]
  10. Gold Rush
    1,498
    Plans
    Sorry we didn't keep track of where the bends were and at what angles. The manager at Exhaust Pro's was very knowledgable and bent the tubes by sight for the most part. You might have luck with your local Exhaust Pro's, they may even weld it in for a decent price for you.
    Good luck,
    David 75K5
