would you take these to a machine shop or take a grinder to them
Discussion in 'The Garage' started by SCOOBYDANNN, Nov 14, 2006.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    to open up the hole to fit over the 60---
    the rims--not the cat
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Do it right.
    Machine shop.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    X Two.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Why...they're not hubcentric. Machined would be cleaner looking but beyond that I don't see a clear reason for it.
    Rene
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    A machine shop w/ a good sized lathe should be able to turn those out for you pretty quickly. They will look 100 x's better done that way. Just my $0.02
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Save the money and do it your self. Don't think you have to take much off to get them to fit.
  7. Drewzz
    Drewzz Registered Member
    Nov 14, 2006
    7
    Regina, Sk, Canada
    If you are taking quite a bit out then machine shop it as there would be less stress involved on the part and if the center gets too thin by overdoing it they are ruined... just my $0.02
  8. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    um they dont fit over as is? ive never heard of anyone else having a problem... Also, if your running the center cap, try it yourself
  9. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
  10. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Swap to a D44 and they'll fit just fine! :D
  11. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    You going to internal beadlocks?
  12. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    Right now im leaning toward the weld on ones. but it all comes down to $$. Rrobably nothing for the time being.
  13. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    machine shop if you ever want to balence them again. unless you find a shop with a lug centering adaptor kit to balence rims. :eek1: :doah: :haha:
  14. 79k20350
    Nov 22, 2004
    7,757
    Ct
    unless hes doing internal balancing... if hes running beadlocks i dobght that standard balancing would be an issue anyways.
  15. Drewzz
    Nov 14, 2006
    7
    Regina, Sk, Canada
    internal balancing has its limits too and is not perfect so why make it worse than it needs to be and if the rims are that bad afterward they are worthless. I get guys that come in with "custom" backyarded rims all the time and they won't balance so we bead them and they are far from perfect with any amount of beads.
  16. goldwing2000
    goldwing2000 Guest
    How much does it have to be opened up? What about using a hole saw?
  17. 79k20350
    Nov 22, 2004
    7,757
    Ct
    You need something to hold the center of a hole saw, in this case it would just dance around.
    Tell me how you would balance that wheel with beadlocks on it...Besides if your putting weights (like standard balancng) on a tire thats going off road your nuts... thy're either gonna fall off or once you chunk a lug they need to be rebalanced.
  18. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    balancing is definately not on my list of mods.
  19. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If you wanna try the hole saw idea, fit a saw the same size as the existing hole onto the same arbor as the larger one. Dunno how it would work, but I've seen it used before.
  20. 1977k5
    May 26, 2003
    9,996
    134
    Since the center of the wheel is very close to the overall center of the whole setup I would doubt that any material loss there would result in much unbalance. Remember, its all about leverage. Look at how much trouble mall crawlers with 44's and clip on weight have with balance.
    If the wheels aren't hub centric (which they're not), who cares if its machined perfectly. Grind it and try and keep it as round as you can and you will be fine.
