WOULD YOU ...
Discussion in '1982-Present GM Diesel' started by K10ANDYKHAMNIC, Nov 24, 2002.
  1. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    PAY $2500 for an unknown condition looks complete , says low miles thats it > 6.2 with th400 and np208 out of a hummvee ?? /forums/images/graemlins/ears.gif
  2. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    They wont tell you any more than that? I would try to find out if it starts. But for the price its not too bad. Thats the exact setup I have and I can tell you it is strong. /forums/images/graemlins/truck.gif
  3. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    You can buy an entire K5 with 6.2 diesel for that. Mine was $1700, WITH 3/4 ton axles under it. My buddy's was $1400, all stock.
  4. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    For that much I wouldnt buy it for that much unless you can see it run!
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Well first off HMMWVs didn't use the NP208. They used the NP218 and later the NP242. Some of the earlier models have been retrofitted with the NP242 because the NP218 is no longer available through normal supply channels.
    A couple of easy ID points on a 6.2 HMMWV motor: low profile open plenum intake, tubular exhaust manifolds left side dumps down - right side dumps straight back, no vacume pump speed signal generator instead, large multi-prong thermo switch (glow plug controller) mounted in the coolant crossover, glowplugs will have a round connector (instead of a spade) and fuel solenoid, HPCA, fast idle will all be Mil-Spec black rubber wire w/"cannon" plugs (no GM "weather packs") /forums/images/graemlins/smirk.gif
  6. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    so its probly out of a cucv then huh ? would i not want one out of a hummveee ? cept for the exhaust ? should i make an offer on just the engine , if so how much they are on pallets so i guess i wont be able to see it run . /forums/images/graemlins/1zhelp.gif
  7. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Being a CUCV means that the fuel solenoid, HPCA, fast idle, & glow plugs were 12V (as opposed to the HMMWVs 24V). Alot of the CUCV glow plugs were (are) crap, plan on replacing them.
    If you knew it's lineage it would be easier to decide. I've seen M1009s (blazer) with lots of hard miles on them. On the same note, right now I have SIX M1031 Contact Maintenance Trucks(built 1986), in my motor pool, each with less than 7500 miles on them! /forums/images/graemlins/laugh.gif
    CUCVs were procured from '84-87 (AFAIK) mostly 85-86. So the lack some of the block improvements of the later years. The good news is the CUCV was never subject to the Army's Oil analysis program so it got regular oil changes. HMMWVs must wait for the OK from the oil lab before it's changed. (And I don't believe much the oil lab says /forums/images/graemlins/mad.gif
    Assuming $400-$500 for a TH400, another $200 for a NP208 (maybe somebody wants one), that still leaves $1800 for the motor; alittle steep - sight unseen. Are there any warranty/garantees? Sure would help if you could pull a head off. /forums/images/graemlins/smirk.gif
  8. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i thought the glow plug system on the cucv was 24v ?? /forums/images/graemlins/confused.gif my m1008 was usmc , one thosevin number things said it was a mail truck. it has a weird flat bracket on the pass side floor board. thw odo shows 11k miles and the rest of the truck looks lke it , almost new.thr door jamb tag says it was built in 83 .on another note a guy from work said he might be getting a diesel sub sometime and i might be able to snag the motor. how many mistakes are there in this post? i typed it without my glasses /forums/images/graemlins/eek.gif /forums/images/graemlins/1zhelp.gif
  9. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    CUCVsglow plugs took 24V power then reduced it to 12V with ballast resistors. 'Wasn't a real good system as the loss of one GP caused an increase in voltage to the other seven (then they died). The flat bracket on the floor was for the Chemical agent detector. DOD may have started procurement in '83 (note AFAIK in previous post). I've never seen anything earlier than '84, and the only reason I remember that is they still used a rope rear main back then /forums/images/graemlins/tongue.gif Who knows what the USMC did, you boys got some weird stuff over their. /forums/images/graemlins/wink.gif
  10. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    hey ive never been in the service ...yet... anyways i got an email back from them and they said that they have 1 under 10k ambulance 6.2 for $2600 .they also say that they fire them up before shipping them . it is at a surplus place . should i make a lower offer or what ? /forums/images/graemlins/1zhelp.gif
  11. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    A used 6.2L with less than 10k miles? I dunno. The last 6.2L was manufactured in 1993. You do the math.
    Have you checked with The Diesel Depot? They have guaranteed used engines, though they have a 100K. I've met the owners personally, and I know you'd be getting a great engine.
    I wouldn't pay that much for a used engine. I had less than $2500 in my 6.2L that I bought from a junkyard, and totally rebuilt.
    Casey
  12. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Just for reference, I just bought a complete m1009 with 23K miles for $623. The price they are asking is extremely high if you ask me. Just my $.02
    Mike
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I've heard the NV242 is quite a nice unit.... It should be a full-time t-case that has true part-time and 2wd operation as well.
    Does that sound right?
  14. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    well how much does the diesel depot ones go for ? id still need all the accessories right ? maybe ill give them a call ...
  15. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    I can believe 10K miles on a old CUCV motor But 10K ARMY miles is not like 10K on your wife's civic /forums/images/graemlins/grin.gif
    Keep this in mind; every driver doesn't "own" it and (many)treats as such, some Army vehicles never see a paved road, and the ones that do get pushed at 65+MPH with 4.56 gears /forums/images/graemlins/angryfire.gif
    say "front & rear main seal leak"
    PS the NP218 and the NV242 are both full-time 4x4 (similiar to the old NP203). With 4HI, 4HI Lock, & 4Low Lock (no 2wd).
  16. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i completely understand the not owning it thing , the border patrol brings us their junk to fix all the time .and our employees do it to the shop trucks ... /forums/images/graemlins/angryfire.gif
