Wow, PS bleed that works!
Discussion in 'The Garage' started by roadnotca, Jan 24, 2007.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    Just in time, thats what I`m doing today:D
  3. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Cool. I found I could crank farther over lock-to-lock, and its back to one hand palm spinning too.
  4. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Cool beans Brent, this is exactly what I needed!
  5. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    X2:D
  7. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
  8. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
  9. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    I normally just fill the system to the cold mark and cycle the steering and adding fluid as needed. Not that hard really.
  10. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Me too, but I just put a new steering box and that routine didn't work...
  11. iwaxmyjimmy
    Nov 3, 2006
    2,802
    34
    Greenville NC
    Did you have the motor running? I forgot to state that I leave the motor off.
  12. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    SOO frustrating. I turned that steering wheel back and forth about 50 times, with the tires in the air and the engine off...still no workie!
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I went there too, maybe. Did you do it slow? Whats not "workie"?
  14. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    Yeah, slow was the name of the game...no workie means that I have no or little Power Assist while driving, it is like driving with manual (non Power)
  15. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Did you disconnect the drag link and ram before you started to bleed the system? I had a hell of a time bleeding mine until I disconnected everything and then it bled in about 5 turns.
    FYI...the ram will act real weird when it's disconnected, just don't worry about it.
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I don't know from Hydro, so what he said.:D
    Was that a tip on the AGR site?
  17. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    No tengo hydro...so I just put the wheels in the air. Will disconnecting things help?
  18. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Can't hurt. Maybe disco the damper(s) too?
    Aw wait; AGR says if it don't work, check for leaks.
  19. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    When I installed my new power steering pump bracket from March Performance, I had to remove it and I drained the fluid. And then when I re-installed it I just put the fluid up to the middle of the cold/hot lines. Then I drove the truck around the block and toped off the fluid, everything worked perfectly, no wierd nioses or hard to steer.
  20. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    My PS box would not reach lock to lock with everything hooked up so it couldn't do a complete cycle. If you look at the AGR instructions it tells you to unhook the drag link and ram.
