Wrapped exhaust on a diesel?
Discussion in 'The Garage' started by 6.2LTrailblazer84, Aug 13, 2005.
  1. 6.2LTrailblazer84
    6.2LTrailblazer84 1/2 ton status
    Jul 4, 2005
    201
    san diego
    I am looking for ways to quiet my diesel beast... I have heard that wrapping the exhaust can help.. and this makes sense since it seems that most the sound propogates from there rather than the engine itself because the engine is so dense.
    So, has anyone tried this? If so, how much did it help with noise reduction and how much did it cost for the wrap itself?
    Also.. I have noticed that when my truck is running and the engine vibrates the exhaust pipes rattles against the metal rod apparatus which holds the exhaust in place. Was there something originally there that held the exhaust in place between the metal rod pieces and the exhaust that was removed or worn out at some point? Some type of hard rubber pieces or something?
  2. Art'74
    Art'74 1/2 ton status
    Dec 21, 2004
    145
    OKC
    I used to frequent a Hummer forum and that spoke of wrapping their exhaust quite a bit. So this info. is not from my experience, just from reading forum input.
    I know they spoke more of heat reduction and HP gain for doing wraps. I do recall it being related to noise reduction some but they also used duramat, etc. So I don't know how much just the wrap helped.
    Sorry I don't have better info.
    Art
  3. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    You have transfer noise... such as vibration etc... good quality isolators can help... the system cant be solid obviously or things would break... poly mounts are made for exhaust work
    The stock mufflers are restrictive but still not quiet... muffler design involves harmonics ets... what works for gas engines may not work for the diesel cycles...
    the guage of the exhaust pipe can also be a factor... heavier gauge absorbing some resonance... I like medium duty mufflers myself.... big long and heavy they absorb gobs of noise
    You have mechanical noise... diesels clickity clack alot.... and that transfers down the exhaust
    One thing that might help is to upgrade the pitiful insulation in the cab... I dynamatted my entire cab... put sheets in each door... extra sheets on the cowl.... it helped immensely,,, EBAY cost about 150.00... the door sheets cut down on the tinny sounds... also I did the roof and back walls... now the thing is new car quiet... with the rumble of the bb under the hood :D
    cam
