wrong keys?!?!?!
Discussion in 'The Garage' started by big83chevy4x4, Apr 11, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my dad bought a 78 blazer a while back and we tried to get it running today and the keys that he gave up were the wrong ones. i would really like to se if this truck runs. is there a way that i can manipulate a key to make it work or anything else that i could do with out destroying the steering colum or the ignition system to get it started?
    Thanks TJ /forums/images/graemlins/truck.gif
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    hotwire it
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    run a hot wire from the battery to the coil and jump the starter to turn it over till it fires up.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i will give it a try. thanks
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Just go down and buy a different ignition for it...
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You can't get that one out without the key...
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i got ahold of the guy that we bought it from, and he is going to look for the keys. it might take him a while to find them, or he may not find them at all. if he doesn't find them then i probably would go buy another ignition. I would rather spend the 20 bucks that it is going to cost me for something else. i don't want to spend the money if i don't have to.
  8. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Lets see if I can remember this.You can pull the plastic piece under the dash and the metal piece, both are directly under the steering column. You will pull out 4 phillips screws in the plastic and two or three more out of the metal.
    Next remove the air conditioning tube that runs to the vent on the far left. Doing all of this should give you access to the wiring on the collum. You will want to get to three main wires.
    The wires you willbe looking for will be thicker than all the rest. 10g if I remember correctly.
    <font color="red"> RED----CONSTANT 12v </font>
    <font color="pink">Pink----Ignition </font>
    <font color="purple">Purple or</font> <font color="yellow">Yellow</font> <font color="purple">-----Should be your starter wire.</font>
    You will want to take and make it so you can access the wires by stripping them back. Jump a wire to the Ignition wire from the Constant 12v lead. This will turn on the ignition, dash lights etc. Just like turning the key. This will need to stay connected for as long as you want the vehicel to run. Next, take a wire from the Constant 12v and touch it to the starter wire. DO NOT WRAP THIS, just hold it. This will trigger the starter. If you have the igintion wire on, it should crank over and start (if the trcuk runs.)
    This should be right. Hope it helps.
  9. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    why not call a locksmith and have new keys made.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    RED----CONSTANT 12v
    Pink----Ignition
    Purple or Yellow -----Should be your starter wire.
    [/ QUOTE ] This is what i was looking for. Thanks im going to play with it tommorow.
    remember this is the blazer that my dad picked up for $76. it would be sweet if it runs. then i can drive it WOOOOOOOOOHOOOOOOOOOO /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If you really want to do this, you can also just remove the switch itself and push the slider with a screw driver... So much easier to "hot wire" without butchering something when the ignition was in the dash.
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i already have it hot wired. just need to throw a battery in it in the morning and fire it up. /forums/images/graemlins/rotfl.gif
  13. mirage
    mirage Registered Member
    Apr 1, 2002
    37
    Mesa, Az
  14. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    IT RUNS /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif it ahd been sitting for about 10 years or so. sprayed alittle starting fluid in it and it started right up. it runs very nice. now i need to put a radiator in it and a the drive shafts and i can drive it /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    got mine out with no key, /forums/images/graemlins/deal.gif
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Without the column being damaged? May I ask how???
