WTB 6" Drop Pitman Arm
Discussion in 'Parts & Trucks Wanted' started by 4bynut, Apr 2, 2006.
  1. 4bynut
    4bynut 1/2 ton status
    Sep 21, 2004
    675
    Morrison, IL
    Hey everyone, I'm looking for a drop pitman arm for a 4x4 box that will work with 6" lift. Let me know what you have. May consider a raised steering arm, but their so much harder to get the old one off. Thanks Jason
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i have never seen a 6" drop arm for a gm 4x4 box. most thay drop is 3"
  3. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    I went to the junk yard when they had 1/2 off and got 2 87 jeep cherokee for $8 then I reamed it out. A machine could ream it out and charge less for both than having to pay $80 or more.
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    4x4 box is diffrent output shaft than the rest on a gm. 1/4 is splined . rest is round and grove cut to let pinch bolt pass threw.
  5. 4bynut
    Sep 21, 2004
    675
    Morrison, IL
    I'll have to check. I just assumed they made them since i have one on another truck with a 4" lift. Maybe I'll have to use a raised steering arm. Or a combination of raised steering arm and drop pitman arm.:confused: I"m using some 6" lift spring i bought used.
    Thanks Jason
  6. sweetk30
    Nov 1, 2004
    25,526
    526
    i ran droped arm with 6" worked just fine. also used raised arm on same before wased to dana 60 worked fine.
    both together will kick it the wrong way and bind. i know.
  7. 4bynut
    Sep 21, 2004
    675
    Morrison, IL
    Still looking!!
