WTB : DOOR
Discussion in 'Parts & Trucks Wanted' started by Tweetysuarus, Oct 22, 2004.
  1. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    4xRick needs a drivers side door for 76-89 Blazer.
    Call him at 206-229-7425
    Thanx,
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well 77 the doors changed again, so,
    73-76 and 77-87(91)
    ive go a couple pass side doors that are good im scrapping, but no driver side ones
    good luck
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    There is a slight difference in doors from 1976. They will work but the door was 1/8 wider. I *think* GM only ran this version for 1 year (Blazer, Jimmy) but I can't remember if it extended to the 77 year or not.
    Like I said, it will work but it makes the gap look much smaller than the other door and down the road, door hang will be more of a problem.
    I suggest you tell your friend to stay clear of 1976 /shrug
  4. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    73-76 and 77-87(91)
    good luck
    73-75 were half doors DUH!
  5. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    There is a slight difference in doors from 1976. They will work but the door was 1/8 wider. I *think* GM only ran this version for 1 year (Blazer, Burb) but I can't remember if it extended to the 77 year or not.
    I had a 1976 Jimmy and used 1977 & 1980 doors on it, no problems!
  6. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Yeah, they work and look the same, just the width is different by 1/8 inch. I prefer the 77 an up. The 73 to 76 are just to close to the tub, especially with a twisted tub /forums/images/graemlins/thumb.gif )
    Not for Trucks and Suburbans, which will fit on your friends rig just the same...
