WTB-Extended Brake Lines/Sway Bar Drops/VortecFuel Lines/14 bolt sf disk
Discussion in 'Parts & Trucks Wanted' started by capps, Jan 22, 2005.
  1. capps
    capps Registered Member
    Feb 6, 2004
    40
    Atlanta (Snellville)
    I have a 1984 3/4 ton 4x4 Suburban. I have installed a 4" lift and would like to purchase some extended brake lines and sway bar drop brackets. I noticed a post from 6 months ago and there were several sets available. Wanted to check before paying retail.
    Also looking for 97 Vortec 350 Fuel lines that run from the frame to the back of the intake. I am installing this in the 84 suburban and this will make the standard to metric conversion much easier. A similar post has photo's of what I am looking for...
    http://coloradok5.com/forums/showthread.php?t=126439
    Also looking for a 100 PSI fuel pump or a good source for one. The vortec requires 65 PSI in the rails to start the engine.
    I have a 14 Bolt SF rear end that I want to do a rear disk brake swap. I have seen many offered on ebay for the full floater, but none for the semi floater. Anyone have the brackets for sale?
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    http://www.tsmmfg.com/2631.htm here's for the disk brakes. you don't need an drop down bracket for you sway bar it should fit fine with out modification.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I will probably have the lines you need. I will let you know soon.
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
  5. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    You will need to get the fuel sender and tank out of a 1987-1991 sub with fuel injection and get the pump from a GM dealer for a 1996 chevy pickup because it was the only year that they used a fuel pump that put out the correct fuel pressure for a vortec engine it looks just like the pump used in a TBI but it puts out the required 65 psi to run the injectors. Just get all the fuel line off of the sub to complete your conversion. Hope this helps out.
    bigred81
  6. capps
    Feb 6, 2004
    40
    The bolt holes on the sway bar are off by about 1/2 inch. I assumed that a drop bracket was required.
    Anyone have extended brake lines or the fuel lines?
  7. capps
    Feb 6, 2004
    40
    From the responses I gather that no one has any of these items that they are not using.
  8. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    Hey capps, I have the stainless steel brake lines that you are looking for and I may have a pair of drop down brackets that I took off of my Suburban. It is too dark outside right now, but I will look for you tomorrow and let you know.
  9. capps
    Feb 6, 2004
    40
    Thanks...Funkycold.. Let me know once you check.
  10. funkycold
    Apr 22, 2002
    435
    Orange County, CA
  11. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    How soon do you need the Vortec fuel lines? I amy have them pulled by the end of the week ready to ship first thing next week. I am trying to sell the engine running local, but need to get rid of the parts truck by Saturday.
  12. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    By the way, how much of the lines do you need? Looks like the filter mounts to the frame under the drivers seat area. Is that where you would want them cut, or somewhere else?
  13. capps
    Feb 6, 2004
    40
    How much do you want for the fuel lines? What year truck are you taking them from?
  14. jac6695
    May 2, 2002
    1,860
    Christiansburg, VA
    I took them from a 98 regular cab pickup. I ended up cutting them about a foot behind the filter. I would like to get $55.00/shipped, but make offer if you feel that is too much. Thanks.
  15. funkycold
    Apr 22, 2002
    435
    Orange County, CA
    Hey Capps do you still want the brake lines and sway bar drops?
    I have them!
    :deal: :deal: :deal: :deal:
  16. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    For the fuel pump I put a TBI sender in my tank and bought a 96-99 OEM intank fuel pump from Auto Zone. Works great. MSD makes an external pump that will work, I tried it but it was way too noisy.
  17. capps
    Feb 6, 2004
    40
    Been out of town. Sending PM now.
