WTB:Front Driveshaft!!
Discussion in 'Parts & Trucks Wanted' started by 86Cucvbeater, Feb 19, 2006.
  1. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    I need it to bolt up to a 1350 series yoke and have a cv joint on the other end that will bolt to a 4 hole flat np-205 flange.
    Oh yeah the distance from the end of the yoke to my t-case flange is right at 30.25 in. Hope someone has somehting!
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    is that basically the stock driveshaft length?
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The 1350 yoke isn't stock. So no stock driveshaft is gonna work.
  4. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Right, I upgraded my yoke and blew up my stock cv joint so thats why I need a new shaft. The length I need should be somewhat longer than stock because I've got 7-8in. of lift and my axle has moved forward an inch. I don't know the proper way to measure so I measured from the tip of the yoke to the tip of the tc flange. The correct measurement I'd have to give high angle driveline for example would be a little longer I bet. Anyone know the correct way to measure?
