WTB: NV4500 damper wheel
Discussion in 'Parts & Trucks Wanted' started by Steve_87K5, Nov 12, 2004.
  1. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    I need the small vibration damper flywheel which is located
    inside the tailshaft housing of the NV4500HD (GM MT8 option).
    It has 32 splines, used in the 4x4 version.
    It is about the size and shape of a coffee can.
    This IS NOT the flywheel associated with the clutch. It is
    a seperate flywheel on the trans output shaft, inside the
    tail housing.
    The part was commonly removed and not used
    when installing certain adaptor kits.
    Maybe someone has one laying around.
    thanks
    Steve
