WTB P30 diiesel tranny adapter for the th400 (for a cummins conversion)
Discussion in 'Parts & Trucks Wanted' started by camiswelding, Oct 17, 2004.
  1. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I am looking for the tranny adapter that went on P30 vans with the 3.9 cummins
    I need the
    adapter (th400 to cummins)
    flange
    flexplate
    starter
    I am gathering pieces for a cummins conversion
    ... Ive found this setup in the "yards" but I want to see if anyone has a super clean one...
    Please Im me
    thanks
    cam
  2. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Something else to consider: use a 727 from a 1st gen dodge. The thing I don't like about the GM adapter is it tilts the motor to one side and the starter isn't as accesible as the dodge/cummins setup. 727s had RH drop NP205s as well, but I bet you already know that /forums/images/graemlins/waytogo.gif.
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The Dodge 727 is also very cheap and easy to rebuild, as well as durable and strong as a TH400 /forums/images/graemlins/thumb.gif Last time I rebuilt one it took about 6-8 hours (my first time rebuilding one too) and less than $300 in parts including the new torque converter. No special tools are required to rebuild it either /forums/images/graemlins/thumb.gif
  4. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    this is a good tip.... I wonder how the linkage would work with the stock chevy linkage or if there is a bunch of mess around? anyone?
    my v3500 205 only has 40k miles on it so I think I would like to use an adapter from the 727 instead of finding a whole cummins 727 205 from a truck... but Im undecided about that...
    any thoughts?
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    any thoughts?
    I have a 727 and the 205 that goes behind it just missing the female sleeve.
    You can't use your 205 since the dodge is 23 spline and the case is the round 6 bolt pattern and the adapter is dodge specific.
    The linkage should work if you had previously a th400, my waggy had the th400 and this one came out of another later model waggy with the same exact configuration except the tranny tcase.
    If you want to buy it I also might sell, but I was just giving you info. /forums/images/graemlins/thumb.gif
    I just got a th400/d20 so might not use the 727/205.
    /forums/images/graemlins/whistling.gif
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    before you go through the whole swap, let me inspect my stuff, I just seperated 2 th400's from 3.9L's..... Let me get a good look at the adapters and I'll snap a few pics if I can bring myself to sell one....
  7. kennyw
    Jun 9, 2002
    13,223
    94
    The inputs can be swapped, and the bolt pattern can be transfered to another T-case /forums/images/graemlins/thumb.gif ORD does this with doubler kits already, mainly re-tapping the NP203's, but I believe there is plenty of metal on the face of a 205 as well. The adapter would need to come from a 727 though.
