WTB Raised steering arm d44 new ubolts same
Discussion in 'Parts & Trucks Wanted' started by norville, Jan 2, 2007.
  1. norville
    norville 1/2 ton status
    Dec 27, 2005
    268
    A stones throw from Pargon Mountaintop Pa
    Hey folks I'm looking for a raised steering arm for a 77 burb w/dana 44 or 10bolt. Lots of years fit. Also new ubolts for the same dana 44. They should be 3.5" center to center and one is bigger?
    Set of shocks for 4" lift.
    Any other things extended like front brake lines. I'll be looking for also.
    If the burb passes inspection I'll just buy them from summit at the end off the week.
    thanks,
    bob
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I have a set of nearly new Rancho ubolts for a 10b/D44 front axle. No rust on them at all. Washers and nuts included as well. $25 plus shipping for the full set.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I said it last week in a different thread and I'm saying it again here:
    It's called RAISED steering arm, not drop.
    When you lift your truck, the steering arm needs to be raised to compensate for the added lift. You don't drop the arm unless you are trying to lower a 4x4 into the weeds to join the lowrider gang?
  4. norville
    Dec 27, 2005
    268
    Yes, correct, raised, my bad. Cant get that past the 2"+ on bone into the grey mush inside :) fixed
    Kenny, were they torqued on? Were they installed at one time? If so I'd rather spent a few more $$ and get a new set. Thanks
    bob
  5. 94yukon
    94yukon 1/2 ton status
    Aug 20, 2005
    122
    Minnesota
    I have a used 4" lift steering arm hows $55+ shipping
  6. norville
    Dec 27, 2005
    268
    Yukon, thanks but I just payed for one. I'll let you know if it falls though. I may also have a set of ubolts.
    thanks Folks
    bob
