WTB: TBI Fuel Lines
Discussion in 'Parts & Trucks Wanted' started by corradofreek, Oct 31, 2006.
  1. corradofreek
    corradofreek 1/2 ton status
    Jan 21, 2004
    164
    Syracuse NY
    Looking for some TBI fuel lines for a 1988. THe line that is needed is the feed line from the fuel filter to the TBI. I know that is two lines. Or, does anyone know if i can use SS braided fuel line to make the run?
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    same flare and nut as gm power steering hoses. just check to seee if nut fits filter. or get repair line ends for the fuel line at napa or others. then use high pressure fuel injection rubber hose and some high pressure clamps.
  3. corradofreek
    Jan 21, 2004
    164
    Syracuse NY
    will the oring from the ps line hold up to the gas, or do i need to change it to the brown nitril oring
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    i have run both with no problems before. i dont need to buy the lines. i can take and make the flares for the oring on any 5/16 and 3/8 line. and if need be for flex i will ise some hp fuel hose with hp clamps. i just put a small bubble in the end of the line to keep the hose from ever thinking of poping off.
  5. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I have the stock braided lines that run down to the frame on my rig. I will be taking them off shortly to put on full AN fittings and lines. If you are interested in my old lines drop me a pm and we can work out the details.
  6. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I sprung a leak right where the SS went to the hard lines. Had to make a quick fix so I cut the hard line and used SS braided all the way up to the TB since I couldnt find any stock ones at local junkyards. I am using 2 hoseclamps on each end and havent had any problems. You can buy the SS lines from Summit. I think 10ft and some hp hoseclamps was around 30 shipped. Spectre is the brand.
