WTB th400 output shaft
Discussion in 'Parts & Trucks Wanted' started by smalltruckbigcid, Apr 17, 2007.
  1. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    I need a 32 spline for a th400 tranny
    to fit a 205...
    Thanks George
  2. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    There are 2 different lengths that fit a 205 depending on whether you have an early style 205 with the short input or the late style with the long input. you might want to specify which one you are looking for.
    Gus
  3. smalltruckbigcid
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    Thanks. I have one of each so I'lll take what I can get
    George
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    I have a th400 output shaft from a 400/208 setup. Sticks out of the back of the tranny 2 3/8", 32 spline. Quick search showed that same dimension for one of the 205 setups. If it'll work, I can pull it out. Front driveshaft went through the side of the trans when one of the park volunteer rangers jumped the truck.
  5. Speedo
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    That is the one that works with the later style 205 with the long input and the round bolt pattern.
    Gus
  6. smalltruckbigcid
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    PM sent...
    George
