WTemp. Sending unit on Vortec heads?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, Jun 13, 2002.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    OK, finally got the heads on the block. The temperature sending unit on the old heads is way too big to put on the Vortec heads. I went to Napa and looked at the unit for a '96 1500 (cause they use the Vortec heads right?) well the new temp sensor has two wires coming out of it. Can I use this? And which wire do I connect the gauge to? I also noticed that the old one fits into a whole on the new intake manifold. Can I just use it there and save myself $25?
    /forums/images/icons/confused.gif
  2. dyeager535
    26,980
    Just use an adapter fitting. I'd assume you can get one, I had to go from a large hole to a small fitting, THAT was an easy adapter to find.
    Two wire units are typically for the ECM, some also probably trigger a coolant warning light in the dash in some applications.
