WTF, 1310 u-joint in 3/4 ton suburban?
Discussion in 'The Garage' started by afroman006, Aug 29, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I bought a 1350 u-joint to replace the front joint in the front shaft, because thats what the rear shaft used, but in fact, the u-joint is a 1310. Wtf is that? So I assume I need a NAPA conversion joint to connect my stock 3/4 ton shaft to my D60. What is the part # for the covnersion joint? Thx
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    All GM front axles (10 bolt, Dana 44 & Dana 60) used the 1310 joint for the pinion yoke. Unless someone swaps out the pinion yoke or driveshaft a 1310 is all you need to connect it.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, all lower fronts are 1310s on GMs. But it's really not as FUBAR as it seems because the 1310 is pretty much always straight (due to CV on top) in anything close to stock configuration. The only time it gets far out of straight is when longer travel suspension or excessive lift (without corrective measures) come into play. As long as it stays close to straight, the 1310 can handle quite a load and is rarely the week point even in 1 ton duties.
  4. afroman006
    Aug 21, 2002
    2,876
    Ok cool. That makes me a bit happier. I just figured since it was a 1 ton axle it would have a 1350 pinion, live and learn /forums/images/graemlins/doah.gif. Thx
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    now you have a spare for the rear /forums/images/graemlins/thumb.gif
  6. afroman006
    Aug 21, 2002
    2,876
    True dat but I already had one of those shitty auto zone lifetime greased ones as a spare lol. /forums/images/graemlins/whistling.gif
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    then buy a couple of 1350 yokes, one slip and one pinion
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Then you break the tube splines. /forums/images/graemlins/eek.gif
  9. afroman006
    Aug 21, 2002
    2,876
    For the cost of the new stuff, I think I can handle carrying an extra u-joint in the burb lol. Thx
