WTF, 205 leaking thru front yoke nut
Discussion in 'The Garage' started by LKJR, Apr 6, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    my fixed yoke 205, on a 71, it appears to be leaking thru the nut on the front yoke, anyone else seen this problem. it's not a small little grease stain it's a drip. (found after I've pulled front driveshaft) also which side of the adaptor (350 auto) is the seal on, or is there seals on both sides of the adaptor to the tranny.
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Don't you hate it when you see someone replied to your post, but when you read it, its totally worthless?? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    My original '72 205 front output did this as well. When I changed the fluid in it, I merely removed the front output yoke and then cleaned it up. After cleaning it I ran a large bead of silicone on the inside of the splines of the yoke and then installed it. This seemed to do the trick. I ran it like that for at least 4 years before I had to remove the yoke because I broke it. Hope this helps.
  4. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    yep, clean it up real good and put silicon around it.
    oil is running by the splines.
    dave
