WTF are SHIMS doing under my front axle???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Oct 2, 2003.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I've gotta tell you I'm not too excited about this. I was putting in my bluetorchfab diff cover last night and looked over at my front axle perches. I almost wet my pants. /forums/images/graemlins/shocked.gif I've got 2 shims shoved in from the front on each side. One is a solid shim, and one has a big groove cut out of the center, lengthwise. The passenger grooved (furthurmore known as POS /forums/images/graemlins/grin.gif) one is cracked, and the driver side POS is trying to work its sorry assss out of there. I was dumbfounded. I've found some real dumbass things in this truck since I've bought it, but stacked shims??????????
    My question is why you would even need a shim in the front in the first place? You have a CV joint in the driveshaft so vibes shouldnt be a concern. Dan has shims (singles) in his as well but he says they came with the truck too. I took some pics last nite, and hopefully danny will get off his lazy butt today and host them for me... /forums/images/graemlins/eek.gif
  2. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Maybe they were trying to fix death wobble or some other handling problems by adjusting the caster /forums/images/graemlins/confused.gif
  3. laketex
    6,220
    North Texas
    Can't I do the same thing by cutting and rotating the knuckles? A little more time consuming I know, but I hate things that are done half-assed!
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    There was a post about this I think, maybe a month ago. Shims used to adjust castor IIRC. Search for HarryH3 posts, I think he 'splained it.
  5. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Is one of the shims part of the leaf spring pack? If its bolted to the pack I wouldn't let it worry you too much, but the grooved ones that could pop out would certainly cause me concern. I can't remember off the top of my head if my lift springs came with a shim installed or not .. hafta look.
  6. laketex
    6,220
    North Texas
    I'm not sure if they're part of the pack or not...no way to really tell i guess unless I stripped the spring pack down. I think i'm going to try sliding the grooved shims out, tighten stuff back down, and see where that leaves me.
  7. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    They are there to SHIM it. /forums/images/graemlins/grin.gif
    I think most lift springs come with them attached to the pack.
    If you have double shims the P O might have put it there for alignment purposes. Yes cutting & turning the axle would be the right thing to do but you know that doesnt always happen.
    Keep in mind if you do deceide to cut & turn them that the frt end is in good shape first.
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    How often does this happen at all? Seems like a lot of work for a few degrees, some steel shims bolted into the spring pack seems like a pretty good way to go, or even a tapered zero rate if one wants a bit more lift.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have ran small shims under mine for years. They came with my 4" Ranchos and I kept them when I threw the Superlifts under. I'm ditching them when I put in my '60 though.
  10. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    how much lift are your springs? I know 8" front springs have them from the factory that way.
  11. laketex
    6,220
    North Texas
    4" lift stiff ass procomps. /forums/images/graemlins/eek.gif
  12. j20m715
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    I didnt mean to come across as shims are WRONG.
    I do agree with you on the tapered zero rates & "the steel bolted in part".
    I do think stacking shims is about as wrong as stacking blocks.
    just my 2 cents.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah I have to agree, stacking shims sounds pretty stupid.
