WTF...degree shim in front springs...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Jul 27, 2002.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I began installing my front 6" lift springs today to gain a little altitude over the 2" lift the previous owner had put on...Upon removal of the front springs, I found a shim mounted between the spring and the axle with he fat part of the shim facing the rear of the axle...what the hell was this for...it is obviously not for driveline angle (although I must say I have never had any vibes) because it is mounted the wrong way...could it be for the camber angle and to help retain the "on-center" steering? Basically, should I toss these with my 6" springs or put them back where I found them?
    Chris
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    They are alignment shims, used to dial in the caster (not camber).
    Positive Caster is like the front forks on a bike.
    At some-point, someone installed the shims to get the front axle caster dieled in to the requested 8- degrees positive. (8 degrees is ALOT of caster)
    Toss 'em (or keep-em hang on to 'em, just incase), install the axle and new springs streight-up and have it aligned after XXX miles, after the spring have had a chance to softend up a bit.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Whoever installed your springs was an idiot. Those shims are to bring driveline angle up when you do a lift. Yes, you'll lose some caster this way, but it's the only way without cutting and welding that you're going to get a decent driveline angle.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I used the shims on my 2.5" front springs,but they are facing the right way. /forums/images/icons/grin.gif
