WTF is going on?!?
Discussion in 'The Garage' started by Wingnutt, Feb 26, 2004.
  1. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    OK I talked to Holley this morning about that TBI and the rep said that I needed to reduce the fuel pressure a bit; no problemo, got home tonight and followed his instructions to the letter. After a bit of tweaking, everything was great, idled at 800rpm and 650 in gear. /forums/images/graemlins/thumb.gif So thinking everything was OK, I got ready to button everything back up. After I put the tools up, I thought what the heck, let me fire this thing once more before I road tested it. That’s when things got interesting, the dang thing wouldn’t idle below 1600rpm! /forums/images/graemlins/yikes.gif I backed the idle adjusting screw all the way out....no dice. Then I sprayed WD40 around the base to check for vaccum leaks, nada. After that, I unhooked the TPS so that the TBI would be completely isolated from the computer...same result.
    Does anybody have ANY idea of what could have happened. This thing is starting to get on my last nerve! /forums/images/graemlins/angryfire.gif TIA
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sounds like maybe something like debris got jammed in the butterflies?? does the holley TBI use an IAC??
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Haha, the same thing happened to my XJ after I decided to power wash the engine compartment. I freaked out, then just said heck with it and drove it like it was. Less than a mile down the road it was back to normal. Can't hurt to try. /forums/images/graemlins/waytogo.gif
  4. Wingnutt
    Feb 20, 2000
    324
    NOVA
    Ya, it uses an IAC and I had that disconnected too ,it's supposed to be a direct replacement. I didn't see anything in the butterflys, they would colse so far they rubbed against the venturi walls.
    I reved it up several times, smae thing. I'm gonna try to get in touch with Holley this morning. One thing that I can say about them, so far they've had great tech support.
    Anybody else?
  5. Grim-Reaper
    7,385
    Atlanta
    The original stuff on adjusting the TPS is wrong inthe instructions. It gives those sort of symptoms. I know two people with the holly stuff that had the same issue.
  6. Wingnutt
    Feb 20, 2000
    324
    NOVA
