Wtf is this thing? Factory limiting strap?
Discussion in 'The Garage' started by sled_dog, Feb 14, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Ok I was looking at the exhaust on my burb trying to see what I would need to do to replace it when I noticed this thing on my rear diff:
    That picture the passenger side is fully stuffed cause I wanted to see if it acted weird when flexing.
    Man this thing needs more flex, and tire.
  2. cuzinjay
    cuzinjay Registered Member
    Feb 13, 2004
    62
    rome ny
    do the brake lines run into it. look like it could be a valve to proportion the brake to the load /forums/images/graemlins/thinking.gif
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Hmm that kind of makes sense. The brakes used to run into it but the previous owner broke it and just ran the straight brake line you can see. Need to strap that to the frame sometime.
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It's the load sensing brake thingy. It gives more breaking pressure in the rear as you get more weight on the rear of the truck.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    My thoughts are if it's not hooked up to help anything, get rid of it. thats what it looks like here, like you said it was used at one time, but no longer, remove it,,, /forums/images/graemlins/waytogo.gif
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Hmm come to think of it, that would explain why my rear brakes lock up first /forums/images/graemlins/ignore.gif /forums/images/graemlins/ignore.gif they are always getting the maximum braking power! Hmm guess I need a prop valve on there.
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    thats whats called a "height sensing proportioning valve"
    and it helps the brakes apply more evenly if the rear springs are compressed.. toyota still uses a setup similar, albeit smaller than that, today..
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    I second all the above info.
    Matter of fact, those didn't start til somewhere around '81 and they were built into ALL 3/4 and 1 ton trucks. /forums/images/graemlins/thinking.gif
