WTF! My carb overflows with gas
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Jan 29, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Another hurdle in my non stop process of getting this K5 to run properly.
    Little back ground on it. It has an electric fuel pump somebody swapped in before I got it, mounted to frame rail. I just rebuilt the carb about 2 weeks ago. It hasn't ran more than about 5 times only for a few minutes at a time since the rebuild of the carb.
    Last night, I was messing around with the blazer. I had the key in the accessory position for about 10 minutes. I started it, it ran really rough and blew tons of blck smoke. I was like WTF, so I popped the hood and took off the air cleaner, puddles of gas on the intake. I turned the key to acc. again to turn the fuel pump on. I watch as gas just fills the carb and begins to leak out of any orifice it can, especially around the accelerator pump shaft.
    What is the deal?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    What kind of carb is it? You might have a bad needle and seat which could cause that.
  3. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Whoops, it's just the stock 4 bbl. Rochester Q-jet.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Might be a bad needle and seat then or you have something stuck in there thats holding it open. Its a common problem. Used to happen to me now and then.
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Might be a bad needle and seat then or you have something stuck in there thats holding it open. Its a common problem. Used to happen to me now and then. Or the float might have become saturated and not foating anymore.
  6. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    The fuel pump sounds like it is wired incorrectly too. It should not be pumping gas in the 'accessory' position, only in the 'on' position. Make sure the hot wire for the pump is connected to the ignition wire. I agree with the other guys about the carb, but you have to re-wire that pump. I have an auxillary elec. fuel pump that I wired through a switch so I can choose when to use it. /forums/images/graemlins/truck.gif
  7. Grim-Reaper
    7,385
    Atlanta
    Either the seat in the carb is bad or the pump has too much pressure. Might want to put a pressure gage on it. 4psi is plenty for a SB350. If it's 7-8 psi either swap it back to mechanical or put a pressure regulator on it.
    As for the wiring...I would put a oil pressure cut off switch in it (see jegs or summit). Wire it to the On selection. Wiring it that way would only alow the pump to come on once there is oil pressure. It's a safety feature.
    The carb should store enough fuel to start and idle before the pump kicks in when the oil pressure come up
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hmmmmmmmm.......my electric pump is wired to come on in the aux. position. It's been working that way for over 8 years and I've never had a problem.
    If your float is working correctly, it should keep the needle down and not allow any more gas into the bowl AS LONG AS THE PUMP DOESN'T HAVE TOO MUCH OUTPUT PRESSURE. FWIW, my pump puts out about 4.5 PSI.
    In fact, I like the fact that the pump comes on before I turn the starter- that way the bowls are always full at start up.
    I'm willing to bet that your needle is stuck in the open position, brother. Sounds like it's time for a rebuild.....
