wtf? popping noise when turning left
Discussion in 'The Garage' started by jace71, Apr 12, 2007.
  1. jace71
    jace71 Registered Member
    Mar 17, 2007
    32
    Georgia
    this just started this morning, I turn the steering wheel to the left about 45* and i feel/hear a popping noise that I can feel under the seat and in the floorboard...any ideas? oh yeah its a 75 k5
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    mine's been doing it for years. I think I saw someone on here say it is the pro comp lift springs I have.
  3. 87K506
    87K506 1/2 ton status
    Sep 18, 2005
    536
    Pitkin, Colorado
    subscribing...my 76 k10 does that occasionally...
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine does that and it is actually the spring pack sliding on itself. I had some one turn the wheel while I looked and one of the leaves would pop out of alignment and make that noise. You feel it in the floorboard area because that is where the rear hanger mounts to the frame.
    I think I need to take my front end apart and check my spring pack pins.
    Also make sure your steering box bolts are tight that can make a popping noise also.
    Ira
  5. THISISWEIRD
    THISISWEIRD 1/2 ton status
    Mar 10, 2007
    165
    WV
    I've got a similar noise and I've isolated it. It's the ball joint on front drag link section...where it attaches.
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Check around your steering box for cracks in the frame.
    Check all bolts.
    Jack up the front end and stick a pry-bar through the rim and move up and down to see if your ball joints or wheel bearings are bad.
  7. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    It could also be the front knuckle u-joint. Make sure it doesn't have any looseness in it.
    Later,
    Buddy
  8. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Mine made a popping noise from the right on right turns, and I could feel it through the body. The body mount behind the right front fender was loose.
  9. jimmy1984
    jimmy1984 1/2 ton status
    Jan 12, 2007
    153
    Napa CA/Oconomowoc WI
    i had that popping in my truck also im pretty sure it is the steering box/frame. The point at wich the steering box connects to the frame tends to get tweeked out or crack after years of stress, and that popping you hear/feel is most likely the frame moving just enough to pop.
  10. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    my '94 c1500 is doing that right now. i think my whole steering linkage is wearing out, but primarily the left outer tie-rod. i realize the setup on our k5s isn't quite the same.
