WTF!!! Soggy Brakes with Discos.....Need Help!!!!!
Discussion in 'The Garage' started by Corey 78K5, Aug 2, 2004.
  1. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Ok I just got all My new brakes on. New rotors front and rear. New calipers and pads front and rear(caddys on the back). I used a power bleeder and got all the air out, and of course used new dot 3 brake fluid. It stops but I have to put the pedal clear to the floor and there isn't much pressure. So what's the problem /forums/images/graemlins/dunno.gif This is not the first time I have done brakes either. It is My first time with the rear disc though.
    /forums/images/graemlins/confused.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/angryfire.gif
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Did you gut the proportioning valve? If not do that.
  3. Corey 78K5
    13,055
    Humboldt County, CA
    /forums/images/graemlins/dunno.gif What the hell do You mean "gut the proportioning valve" /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. zcarczar
    Feb 10, 2002
    2,495
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Do you have the bleeder screw pointing up? You may need to take the caliper off to bleed it depending on whose disc bracket you have and how you have it mounted.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    "caddie calipers"
    Did you adjust the rear calipers?Did you reconnect the e-brake to the e-brake levers on the Caddie calipers?
    If the e-brake cable is connected push the e-brake pedal to the floor a few times.This will "mechanically" bring the pads as close as possible to the rotor.Taking up any slack and will help firm up the pedal.
  7. Corey 78K5
    13,055
    Humboldt County, CA
    Thanks Guy's I will try what you suggested /forums/images/graemlins/peace.gif
