WTF...Truck overheating when it is 10 degrees outside?1?!?!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Feb 7, 2003.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Okay, I woke up this morning at my girlfriends and went outside to start my trcuk...I let it warm up for a good 10 min then got in and headed to my house...Even by the time I got to my house, there was no heat, which is really unusual for my rig...it usually heats up pretty quick...So I drove it around the neighbourhood a bit to get a littlie heat in her...Well just as I was passing my house for the third time, I could smell the oh-so-sweet smell of coolant...I pulled into my driveway and poped the hood as steam billowed out and and water puked out of the coolant resivour....Now what is the deal? I had NO heat in the truck but the coolant in the Rad was hot enough to overflow the resivour? Did my coolant like freeze in the engine last night or something...whats the deal gang...I am gonna pick up a new rad cap., coolant and t-state today at work...Oh and there was enough pressure in the colling system to make coolant pukle from the intake manifold at the junction witht he cyl. head...Possible a stuck t-stat?? Lemme know gang...I really appreciate you help...
    Chris
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Your radiator is probably frozen. /forums/images/graemlins/shocked.gif Sounds like you don't have enough antifreeze in the coolant. You'll need to get the radiator warmed up, then drain out some of the coolant and then replace it with straight antifreeze. Then use a coolant tester to see what temp you're protected to. Any parts store will have the Prestone coolant tester. I have all my junk setup to withstand at least -34 degrees F.
  3. rodriscoll
    rodriscoll Registered Member
    Feb 7, 2003
    18
    Townsend, MA
    Yes I would say definetly stuck thermostat no heat and overheating are a sure sign
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    When you first started it, all of the coolant was most likely frozen. But the engine heat thawed out the coolant in the block. But with the coolant in the radiator still frozen, the coolant can't circulate to transfer its heat to the radiator. It eventually will thaw out the upper radiator hose and then force the coolant out of the overflow tube because the coolant in the engine is HOT!
    I'll bet your low temp last night was way below 10 degrees. I'm at least 100 miles south of you and the low here was 2 below zero last night. /forums/images/graemlins/shocked.gif
  5. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    Yup, i'd say your radiator, also check to see if the clutch on your fan.. before you start it up in the morning try to turn the fan with your hand(engine off /forums/images/graemlins/thumb.gif) if it's hard to turn your cluch is o.k. and it "sucks" but if the fan's easy to turn then your fan clutch is bad and that's your problem.. the fan's not sucking air through the radiator so it's not cooling the water/coolant.. that's what happened to my car and when i took the radiator cap off the water would look like a Geizer and shoot coolant like 5 feet in the air, it sucked but i bet it was a good show for the passers-by ... good luck.
  6. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    I've seen cars freeze the radiator driving down the road. Lived by the top of I80 over Donner Summitt. Flatlanders would come up from Sacto etc. and not have enought antifreeze in the system. The radiator would freeze up while they're driving down the road. /forums/images/graemlins/blush.gif
  7. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    If the fan is hard to turn when the motor is cold then the clutch is bad. The reason for the clutch is that when you fire up the motor and the water inside is cold you don't want to pull tons of air thru the radiator. As the motor warms up the fan pulls harder to keep it cool. That's the way I understand it anyways.
  8. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    That happened with my Crew Cab last winter when it got cold here. My friend that works at a radiator shop told me that usually the coolant in the heater core freezes, so theres no heat in the cab (just cold air) and theres not very good circulation of coolant.
    My radiator was fine. He suggested putting a heater in the cab to thaw out the heater core. I just waited until it got warmer out to drive it, drained some coolant then added more antifreeze.
  9. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I think harry got it.../forums/images/graemlins/thumb.gif I just replaced the t-stat, cap, and coolant and she is good to go...Thanks for the help gang...
    Chris
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Didja spend $3 for the coolant tester? I use mine every fall to check all my rigs. It's much less hassle than swapping an engine because of a cracked block. /forums/images/graemlins/shocked.gif It's got a rubber bulb that pulls some coolant up into the tester, then a needle swings up to indicate what temp you're protected to. /forums/images/graemlins/cool.gif It's easier than falling off a log and takes the guesswork out of mixing the coolant. /forums/images/graemlins/wink.gif Picked mine up at Walmart. /forums/images/graemlins/cool.gif
  11. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    lmao...I had to dish out all of $1.89 (that is with my discount /forums/images/graemlins/thumb.gif) at Napa...Should've used one in the first place, then again, hindsight is 20/20 Thanks for you help Harry...
    Later
    Chris
