WTF!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz88K5, Jun 10, 2001.
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    ok this is pissin me off bad.....my rear diff started leaking from the trip to frank raines....well i pulled it off cleaned it up resealed it and put it back on..well filled it back up with oil and drove back home...well i pull in the drive way...and go inside get all cleaned up and walk back out and then WTF!!!!!!!!!.....the leak is worse than it was before....now i have to redo it again...i am really pissed
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Check the vent tube on the top of the differential. If it is plugged up, there will be pressure building up inside and the oil is going to "burst". In your case, its going to "burst" out the gasket seams. Just take the rubber hose off at the axle housing end and check it out. You could also check the plastic vent at the top of the hose up in the frame rails, too. Blow thru the rubber hose just to make sure there are no obstructions.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The wife's Cherokee had that problem - turned out to be the vent cap.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  4. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    bet
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    How much? [​IMG]
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Bet..that -k30- right.
    Twiztid
