Wtf?!?
Discussion in 'The Garage' started by LEEREED123, Apr 23, 2007.
  1. LEEREED123
    LEEREED123 1/2 ton status
    Jun 29, 2006
    384
    BFE, Ga
    Strangest thing happened on the way to work today in my 91. the cruise control stopped working and my abs light started flashing erraticly.
    what gives?!?
    any ideas?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Brake switch :dunno: First thing I'd check .
  3. dyeager535
    26,981
    The erratic flashing is probably a code. For the ECM trouble codes it was long and short flashes of the light to differentiate between the first and second digit of the code.
  4. LEEREED123
    Jun 29, 2006
    384
    BFE, Ga
    actually, it's not flashing like a diagnostic code, just like a flickering light bulb. checked diagnostic codes and nothing is showing.
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Speed sensor is the first thing that comes to mind. As far as I know it's the only thing that the cruise and the ABS has in common.
  6. LEEREED123
    Jun 29, 2006
    384
    BFE, Ga
    ok, the light flashes like crazy, but if i unplug the abs module, it goes out.
    does that help?
  7. dyeager535
    26,981
    If speed sensor was screwed up, the speedometer wouldn't work either.
    I'd check the brake switch, cruise and ABS are the only thing in common there, since the brake switch will turn off cruise.
  8. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    not necessarily, if a segment on the tone ring is bad or it is an intermittent "no read" problem then the speedo may still work, it would probably jump on occasion though.
  9. LEEREED123
    Jun 29, 2006
    384
    BFE, Ga
    well, seems like it's down to the brake switch and VSS.
    the brake switch is $6, and the VSS is 95.
    i'll try the brake switch 1st.
    i'll let you know!
    thanks!
  10. dyeager535
    26,981
    You should be able to test the brake switch, it's a simple open/closed piece. It may just be out of adjustment.
  11. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    i bet on speed sensor.
