WTH, I think I burned up both axels
Discussion in 'The Garage' started by MEGALADON, Mar 28, 2006.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    I was at a friends house in the woods, and they had a new black top rd.
    We went riding around, and I thought I would down shift, and floor it :D .
    Boy was it fun (454/350trans). Bad thing is I plit the trans in half :doah: .
    U-HAUL did not have a trailer or dollie to pull my truck home, about
    40 miles away from my house. My friend suggest we pull it with his truck.
    No big deal. I put the transfer case in neutral and the trans in neutral.
    We stop to get gas, for his truck, and at some point, I'm sure when we stoped for gas I put the trans in park. We took of, And I forgot to put the trans in neutral again. So at this point the T/C is the only one in neutral :doah:
    We get about 30 miles from my house and I smell gear iol burning and notice
    my truck feel real heavy on the pull. I get the driver to pull over and I get out the truck, look underneath and both my DIFF's front and rear are SMOKING
    BAD.
    I put the trans in neutral and the T-C is still in neutral, I hope it worked.
    2 miles in the pull the truck felt heavier:eek1: , we pull over again and the DIFF's are smoking real bad, PURE WHITE TO, like if they got red hot. Well the truck did not want to budge. I ended up calling a flat bed (SAFE CLEAR SUCKS)
    and they came out with a normal tow truck. He lifted it upfrom the front and moved it back and forth a foot or so, and it seem to be binding in the rear,
    the rear wheels would move then lock up. I'm pissed at this point, I tell the wrecker driver to give me a 7/16 to pull the rear drive shaft. I pull it off and truck moves freely now :confused: . We get it home, he drops it off in my drive way and it would roll with out the rear shaft:confused: .
    I dont understand how my diff's would get so FREAKIN HOT.
    The gear oil on the front shaft shot out one side. What did I do?????
    Did I ruin my T/C???
  2. Propayne
    Propayne Registered Member
    Nov 27, 2005
    67
    San Angelo, TX
    i dont understand why the front differential would have any problems at all. to me the problem lies in the t-case being in neutral. i say this because when i took my drive shaft off, putting it in park did nothing because the rear diff wouldnt lock up.
    thats basically all i know, someone else should know
  3. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I am so confused. :confused:
    I'll take pic's when I get out of work and post them.
  4. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    I don't get it, the diffs front and rear are smoking, but when you take the driveshafts off the diffs it rolls freely?
    Where the diffs hot to the touch? What about the trans?
  5. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    Yea, both diff's were smokin super hot, the gear lube up front
    shot out the driver side axel seal. both covers turned ghost white.
    The trans is split in half, but still in. I will post pic's later.
    I just don't get it. The T/C was in neutral the whole time.
  6. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    I personally think you had more problems than just your tranny splitting. Maybe your axles caused the tranny failure. Once the transfer case is in neutral it should roll very easily even if the tranny is in park. Also my transfer case in neutral cause boths driveshaft to turn. Don't know if this caused some issues you might have had with a locker in the front.
  7. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
  8. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    The front shouldn't turn unless you didn't unlock your hubs. Or do you have full time 4x4? Correct me if I'm wrong, but I don't think was available in 82.
    Wait, if you put the tranny in park then that shouldn't do anything if the t-case was in nuetral. Are you sure the t-case was fully in neutral?
  10. ct85k10
    ct85k10 1/2 ton status
    Oct 25, 2005
    121
    Charlotte, NC
    i was about to say the same thing^
  11. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    Yup, it was in neutral.
    I do not have to lock or unlock my hubs. I can just put it in 4X4
    mode from inside the the truck, and unlock it from inside also. I have
    to back up like 10 feet in reverse to unlock it.
  12. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Ah, auto hubs, thats what I have they are kinda crapy but slightly convinient. Your front drive shaft shouldn't be stinning if your hubs are unlocked.
  13. ct85k10
    Oct 25, 2005
    121
    Charlotte, NC
    if you have auto hubs the rear shaft would turn the front ^and lock the hubs
    so your axels are locked together which can be very bad on dry pavement at highway speed
    just like driving on dry pavment in 4x4
  14. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Couldn't you have just left the tcase in 2wd? Putting it in neutral would lock your front auto lock hubs, so leaving it in 2wd would keep just the rear driveshaft spinning, right?
  15. ct85k10
    Oct 25, 2005
    121
    Charlotte, NC
    right thats what the factory sugests you do if you are going under 50 miles more than you should pull the shaft
  16. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I could have, but i did not know the neutral T/C locked the front hubs :confused:
    If that even happened.
  17. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    That's what my '85 K5 (700R4/NP208/autohubs) owner's manual indicates:
    [Towing this vehicle] with all four wheels on ground
    1. TC in 2H
    2. Trans in neutral
    3. Max speed 35mph
    4. Max distance 50 miles
    Note: For speeds over 35mph or distances over 50 miles, remove front propshaft and store in vehicle. Disconnect the rear propshaft [because it's a slip-yoke into the TC] at the rear axle carrier and secure in a safe position [so that the slip-yoke won't slip-out]. Tape u-joint bearing journal caps securely in place.
    That's Chevy's boldfaced note, not mine, but I did add the non-boldface comments. There are also similar instructions for front wheels off ground, as well as rear wheels off ground. Socket set. Some wrenches. Fibertape. Mechanic's wire.
  18. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    what, the rear drive shaft ??
    I did not pull the shaft, because the tranny was already toast.
  19. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Have you pulled the diff covers yet?
  20. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    Nope, but i will tonite. I really want to see how they look inside.
