Wth?? Np 205?
Discussion in 'The Garage' started by BKinzey, Jan 25, 2007.
  1. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Not sure if it's a NP205 or not but i don't think Chevy ever used a divorced 205. The divorced 205 was mainly a Dodge thing IIRC.
  3. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Is that possibly a NP200
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    No on the NP200, NP200 had rear drive shaft on same shaft as front drive shaft.
    I think there was a NP202 that was for medium size truck prior to NP205.
    Looks like some sort of drive line brake on it???
  5. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    What exactly does "divorced" mean anyway?
  6. dremu
    Feb 27, 2000
    15,967
    458
    East of San Francisco
    Doesn't connect directly to the transmission, the way you're used to; it has a (potentially very short) drive shaft from the tranny to the t-case input.
    You'd use a 2WD tranny with a U-joint yoke on it, a short shaft, and then this thing.
    Only really useful on loooong trucks, burbs and pickups, especially crewcabs, or if you're doing crazy drivetrain things (dual rear axles or quadruple transfer cases or something.)
    -- A
  7. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    chevy did use them 70ish and older some had them. and iirc it was a rockwell unit.
  8. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    I'm going to agree with Goose on this one. I'm pretty sure it's a NP202, but for some special industrial application. Look at the rear output, it appears to be light duty as compared to the front output, which with that rear cover, is much heavier duty than standard 202/205.
    My guess is it's from a forklift or somesuch that used the rear output to drive a PTO or something, and the front output was for locomotion. That rear cover on the front output has to be for a tapered roller bearing, as opposed to the (relatively) light duty caged needle bearing cover of a 205.
    My .02
    Jimbo
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    That's no 205... :eek:
    Marv
  10. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Thats no 205 allright!! Not a Chevy either, inless it's for a 2 tonner or something bigger. I have some kind of div case that is in my 62, looks nothing like that. Chevy used div cases in all 60-66s, then in 67-72 or so only the 1 tons had a div case. After that it's Intersmashable and Dodge.
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Almost certain thats a NP200 or 201. I am leaning towards a 201. Definitely not a NP202, they have shift rails stacked on top of each other.
